Efficient construction of high-resolution TVD conservative schemes for equations with source terms: application to shallow water flows, International Journal for Numerical Methods in Fluids, vol.21, issue.8, pp.209-248, 2001. ,
DOI : 10.1137/0721062
Benchmarking a multiresolution discontinuous Galerkin shallow water model: Implications for computational hydraulics, Advances in Water Resources, vol.86, pp.14-31, 2015. ,
DOI : 10.1016/j.advwatres.2015.09.016
Free-surface fluctuations and turbulence in hydraulic jumps, Experimental Thermal and Fluid Science, vol.35, issue.6, pp.896-909, 2011. ,
DOI : 10.1016/j.expthermflusci.2011.01.009
Convective transport of air bubbles in strong hydraulic jumps, International Journal of Multiphase Flow, vol.36, issue.10, pp.798-814, 2010. ,
DOI : 10.1016/j.ijmultiphaseflow.2010.05.006
Particle image velocity measurement and meshfree method modeling study of forced hydraulic jumps, Journal of Hydraulic Engineering, vol.143, issue.9, 2017. ,
DOI : 10.1061/(asce)hy.1943-7900.0001325
SWASHES: a compilation of shallow water analytic solutions for hydraulic and environmental studies, International Journal for Numerical Methods in Fluids, vol.74, issue.3, pp.269-300, 2013. ,
DOI : 10.1002/fld.3865
URL : https://hal.archives-ouvertes.fr/hal-00628246
TVD schemes for open channel flow, International Journal for Numerical Methods in Fluids, vol.121, issue.7, pp.791-809, 1998. ,
DOI : 10.1007/978-3-0348-5116-9
Implicit high-resolution methods for modelling one-dimensional open channel flow, Journal of Hydraulic Research, vol.32, issue.5, pp.369-381, 2000. ,
DOI : 10.1016/0021-9991(87)90049-0
Proceedings of the 2nd workshop on dam-break wave simulation, Départment Laboratoire National d'Hydraulic, 1997. ,
Classical hydraulic jump: sequent depths, Journal of Hydraulic Research, vol.10, issue.5, pp.565-585, 1989. ,
DOI : 10.1080/00221687609499663
Classical Hydraulic Jump, J. Hydraul. Res, vol.28, pp.591-608, 1990. ,
DOI : 10.1007/978-94-015-8048-9_2
Open Channel Flow, 1966. ,
Application of a second-order Runge???Kutta discontinuous Galerkin scheme for the shallow water equations with source terms, International Journal for Numerical Methods in Fluids, vol.100, issue.23, pp.805-821, 2008. ,
DOI : 10.1007/978-3-642-59721-3_42
URL : https://hal.archives-ouvertes.fr/hal-00707382
Simple and efficient solution of the shallow water equations with source terms, International Journal for Numerical Methods in Fluids, vol.118, issue.5, pp.313-340, 2010. ,
DOI : 10.1002/fld.2071
Analysis and computation of steady open channel flows, 1996. ,
Steady open channel test problems with analytic solutions, 1995. ,
Analytic Benchmark Solutions for Open-Channel Flows, Journal of Hydraulic Engineering, vol.123, issue.11, pp.1041-1044, 1997. ,
DOI : 10.1061/(ASCE)0733-9429(1997)123:11(1041)
Relation of surface roller eddy formation and surface fluctuation in hydraulic jumps, Journal of Hydraulic Research, vol.2, issue.5, pp.207-212, 2004. ,
DOI : 10.1063/1.857630
A large time step 1D upwind explicit scheme (CFL>1): Application to shallow water equations, Journal of Computational Physics, vol.231, issue.19, pp.2316532-6557, 2012. ,
DOI : 10.1016/j.jcp.2012.06.017
