Multipath Load Balancing in SDN/OSPF Hybrid Network
Software defined network (SDN) is an emerging network architecture that has drawn the attention of academics and industry in recent years. Affected by investment protection, risk control and other factors, the full deployment of SDN will not be finished in the short term, thus it results into a coexistence state of traditional IP network and SDN which is named hybrid SDN. In this paper, we formulate the SDN controller’s optimization problem for load balancing as a mathematical model. Then we propose a routing algorithm Dijkstra-Repeat in SDN nodes which can offer disjoint multipath routing. To make it computationally feasible for large scale networks, we develop a new Fast Fully Polynomial Time Approximation Schemes (FPTAS) based Lazy Routing Update (LRU).
Informatique [cs]
