Spanning forests of a digraph and their applications, Automation and Remote Control, vol.62, issue.3, pp.443-466, 2001. ,
DOI : 10.1023/A:1002862312617
Local Graph Partitioning using PageRank Vectors, 2006 47th Annual IEEE Symposium on Foundations of Computer Science (FOCS'06), pp.475-486, 2006. ,
DOI : 10.1109/FOCS.2006.44
Pagerank based clustering of hypertext document collections, Proceedings of the 31st annual international ACM SIGIR conference on Research and development in information retrieval, SIGIR '08, pp.873-874, 2008. ,
DOI : 10.1145/1390334.1390549
URL : https://hal.archives-ouvertes.fr/inria-00565355
Generalized Optimization Framework for Graph-based Semi-supervised Learning, Proceedings of SIAM Conference on Data Mining, 2012. ,
DOI : 10.1137/1.9781611972825.83
URL : https://hal.archives-ouvertes.fr/inria-00633818
On the Choice of Kernel and Labelled Data in Semi-supervised Learning Methods, Algorithms and Models for the Web Graph, pp.56-67, 2013. ,
DOI : 10.1007/978-3-319-03536-9_5
URL : https://hal.archives-ouvertes.fr/hal-00924132
Beta Current Flow Centrality for Weighted Networks, Proceedings of the 4th International Conference on Computational Social Networks, p.9197, 2015. ,
DOI : 10.1007/978-3-319-21786-4_19
URL : https://hal.archives-ouvertes.fr/hal-01258658
Discrete dynamic programming " . The Annals of Mathematical Statistics, pp.719-726, 1962. ,
Semi-supervised Classification from Discriminative Random Walks, Machine Learning and Knowledge Discovery in Databases European Conference Proceedings, Part I, ser, pp.162-177, 2008. ,
DOI : 10.1007/978-3-540-87479-9_29
URL : http://www.info.ucl.ac.be/~pdupont/pdupont/pdf/dwalks_ecml08.pdf
Semi-supervised learning, 2006. ,
DOI : 10.7551/mitpress/9780262033589.001.0001
Aggregation of preferences by the generalized row sum method, Mathematical Social Sciences, vol.27, issue.3, pp.293-320, 1994. ,
DOI : 10.1016/0165-4896(93)00740-L
Spanning forests and the golden ratio, Discrete Applied Mathematics, vol.156, issue.5, pp.813-821, 2008. ,
DOI : 10.1016/j.dam.2007.08.030
URL : https://doi.org/10.1016/j.dam.2007.08.030
The graph bottleneck identity, Advances in Applied Mathematics, vol.47, issue.3, pp.403-413, 2011. ,
DOI : 10.1016/j.aam.2010.11.001
URL : https://doi.org/10.1016/j.aam.2010.11.001
The matrix-forest theorem and measuring relations in small social groups " . Automation and Remote Control, pp.1505-1514, 1997. ,
On a duality between metrics and ?-proximities " . Automation and Remote Control, pp.608-612, 1998. ,
On proximity measures for graph vertices, Automation and Remote Control, vol.59, issue.10, pp.1443-1459, 1998. ,
The forest metrics of a graph and their properties, Automation and Remote Control, issue.8, pp.61-1364, 2000. ,
Coverings, heat kernels and spanning trees, Electronic Journal of Combinatorics, vol.6, p.12, 1999. ,
Discrete Green's Functions, Journal of Combinatorial Theory, Series A, vol.91, issue.1-2, pp.191-214, 2000. ,
DOI : 10.1006/jcta.2000.3094
The heat kernel as the pagerank of a graph, Proceedings of the National Academy of Sciences, vol.51, issue.50, pp.19735-19740, 2007. ,
DOI : 10.1002/rsa.3240040402
A local graph partitioning algorithm using heat kernel pagerank, Proceedings of WAW 2009, pp.62-75, 2009. ,
DOI : 10.1007/978-3-540-95995-3_6
URL : http://www.math.ucsd.edu/~fan/wp/kernel_local.pdf
On certain linear mappings between inner-product and squared-distance matrices, Linear Algebra and its Applications, vol.105, pp.91-107, 1988. ,
DOI : 10.1016/0024-3795(88)90006-7
URL : https://doi.org/10.1016/0024-3795(88)90006-7
Geometry of Cuts and Metrics, Algorithms and Combinatorics, vol.15, 1997. ,
DOI : 10.1007/978-3-642-04295-9
URL : http://www.liga.ens.fr/~deza/BOOK1/cutbook.pdf
An experimental investigation of kernels on graphs for collaborative recommendation and semisupervised classification, Neural Networks, vol.31, pp.31-53, 2012. ,
DOI : 10.1016/j.neunet.2012.03.001
New ridge parameters for ridge regression, Journal of the Association of Arab Universities for Basic and Applied Sciences, pp.94-99, 2014. ,
DOI : 10.1016/j.jaubas.2013.03.005
URL : https://doi.org/10.1016/j.jaubas.2013.03.005
An Experimental Investigation of Graph Kernels on a Collaborative Recommendation Task, Sixth International Conference on Data Mining (ICDM'06), pp.863-868, 2006. ,
DOI : 10.1109/ICDM.2006.18
Distances in Weighted Trees and Group Inverse of Laplacian Matrices, SIAM Journal on Matrix Analysis and Applications, vol.18, issue.4, pp.827-841, 1997. ,
DOI : 10.1137/S0895479896298713
The Stanford GraphBase: a platform for combinatorial computing, 1993. ,
Diffusion kernels on graphs and other discrete input spaces, Proceedings of ICML, pp.315-322, 2002. ,
On Some Ridge Regression Estimators: An Empirical Comparisons, Communications in Statistics - Simulation and Computation, vol.32, issue.3, pp.621-630, 2009. ,
DOI : 10.1080/02664760500078946
Finding and evaluating community structure in networks, Physical Review E, vol.65, issue.2, p.26113, 2004. ,
DOI : 10.1103/PhysRevE.68.065103
Markov decision processes: Discrete stochastic dynamic programming, 1994. ,
DOI : 10.1002/9780470316887
An analysis of variance for paired comparisons, Journal of the American Statistical Association, vol.47, issue.259, pp.381-400, 1952. ,
Kernels and Regularization on Graphs, Proceedings of the 16th Annual Conference on Learning Theory, pp.144-158, 2003. ,
DOI : 10.1007/978-3-540-45167-9_12
URL : http://mlg.anu.edu.au/~smola/./papers/SmoKon03.ps
A family of dissimilarity measures between nodes generalizing both the shortest-path and the commutetime distances, 14th ACM SIGKDD Intern. Conf. on Knowledge Discovery and Data Mining, pp.785-793, 2008. ,
Spectral clustering and transductive learning with multiple views, Proceedings of the 24th international conference on Machine learning, ICML '07, pp.1159-1166, 2007. ,
DOI : 10.1145/1273496.1273642
URL : http://imls.engr.oregonstate.edu/www/htdocs/proceedings/icml2007/papers/575.pdf
Learning with local and global consistency, Advances in Neural Information Processing Systems, pp.321-328, 2004. ,
Semi-supervised learning using Gaussian fields and harmonic functions, Proceedings of ICML 2003, pp.912-919, 2003. ,
Semi-supervised learning literature survey, 2005. ,
