Automatic single- and multi-label enzymatic function prediction by machine learning - Archive ouverte HAL Access content directly
Journal Articles PeerJ Year : 2017
(1) , (1) , (2) , (3) , (1, 3)
1
2
3
The number of protein structures in the PDB database has been increasing more than 15-fold since 1999. The creation of computational models predicting enzymatic function is of major importance since such models provide the means to better understand the behavior of newly discovered enzymes when catalyzing chemical reactions. Until now, single-label classification has been widely performed for predicting enzymatic function limiting the application to enzymes performing unique reactions and introducing errors when multi-functional enzymes are examined. Indeed, some enzymes may be performing different reactions and can hence be directly associated with multiple enzymatic functions. In the present work, we propose a multi-label enzymatic function classification scheme that combines structural and amino acid sequence information. We investigate two fusion approaches (in the feature level and decision level) and assess the methodology for general enzymatic function prediction indicated by the first digit of the enzyme commission (EC) code (six main classes) on 40,034 enzymes from the PDB database. The proposed single-label and multi-label models predict correctly the actual functional activities in 97.8% and 95.5% (based on Hamming-loss) of the cases, respectively. Also the multi-label model predicts all possible enzymatic reactions in 85.4% of the multi-labeled enzymes when the number of reactions is unknown. Code and datasets are available at https://figshare.com/s/a63e0bafa9b71fc7cbd7.
J26_Amidi_PeerJ_2017.pdf (1.51 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-01648529 , version 1 (26-11-2017)
Identifiers
Cite
Shervine Amidi, Afshine Amidi, Dimitrios Vlachakis, Nikos Paragios, Evangelia I. Zacharaki. Automatic single- and multi-label enzymatic function prediction by machine learning. PeerJ, 2017, 5, pp.1-16. ⟨10.7717/peerj.3095⟩. ⟨hal-01648529⟩
108 View
121 Download
Share
