Prediction of protein function using a deep convolutional neural network ensemble - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PeerJ Computer Science Année : 2017
Background. The availability of large databases containing high resolution three-dimensional (3D) models of proteins in conjunction with functional annotation allows the exploitation of advanced supervised machine learning techniques for automatic protein function prediction. Methods. In this work, novel shape features are extracted representing protein structure in the form of local (per amino acid) distribution of angles and amino acid distances, respectively. Each of the multi-channel feature maps is introduced into a deep convolutional neural network (CNN) for function prediction and the outputs are fused through support vector machines or a correlation-based k-nearest neighbor classifier. Two different architectures are investigated employing either one CNN per multi-channel feature set, or one CNN per image channel. Results. Cross validation experiments on single-functional enzymes (n = 44,661) from the PDB database achieved 90.1% correct classification, demonstrating an improvement over previous results on the same dataset when sequence similarity was not considered. Discussion. The automatic prediction of protein function can provide quick annotations on extensive datasets opening the path for relevant applications, such as pharmacological target identification. The proposed method shows promise for structure-based protein function prediction, but sufficient data may not yet be available to properly assess the method's performance on non-homologous proteins and thus reduce the confounding factor of evolutionary relationships.
J28_Zacharaki_PeerJ-CS_2017.pdf (5.43 Mo) Télécharger le fichier
hal-01648534 , version 1 (26-11-2017)
Evangelia I. Zacharaki. Prediction of protein function using a deep convolutional neural network ensemble. PeerJ Computer Science, 2017, 3, pp.1-17. ⟨10.7717/peerj-cs.124⟩. ⟨hal-01648534⟩
209 Consultations
595 Téléchargements
