Sampling from a log-concave distribution with compact support with proximal Langevin Monte Carlo - Archive ouverte HAL Access content directly
Journal Articles Proceedings of Machine Learning Research Year : 2017
(1, 2) , (3) , (1, 2) , (4)
1
2
3
4
This paper presents a detailed theoretical analysis of the Langevin Monte Carlo sampling algorithm recently introduced in [DMP16] when applied to log-concave probability distributions that are restricted to a convex body K. This method relies on a regularisation procedure involving the Moreau-Yosida envelope of the indicator function associated with K. Explicit convergence bounds in total variation norm and in Wasserstein distance of order 1 are established. In particular, we show that the complexity of this algorithm given a first order oracle is polynomial in the dimension of the state space. Finally, some numerical experiments are presented to compare our method with competing MCMC approaches from the literature.
main.pdf (516.76 Ko) Télécharger le fichier
Dates and versions
hal-01648665 , version 1 (27-11-2017)
Identifiers
  • HAL Id : hal-01648665 , version 1
Cite
Nicolas Brosse, Alain Durmus, Éric Moulines, Marcelo Pereyra. Sampling from a log-concave distribution with compact support with proximal Langevin Monte Carlo. Proceedings of Machine Learning Research, 2017, 65, pp.319-342. ⟨hal-01648665⟩
236 View
72 Download
Share
