An introduction to MCMC for machine learning, Machine learning, pp.5-43, 2003. ,
An Adaptive Version for the Metropolis Adjusted Langevin Algorithm with a Truncated Drift, Methodology and Computing in Applied Probability, vol.22, issue.2, pp.235-254, 2006. ,
DOI : 10.1007/978-1-4757-4145-2
Convergence to equilibrium in Wasserstein distance for Fokker???Planck equations, Journal of Functional Analysis, vol.263, issue.8, pp.2430-2457, 2012. ,
DOI : 10.1016/j.jfa.2012.07.007
URL : https://hal.archives-ouvertes.fr/hal-00632941
Analysis and geometry of Markov diffusion operators, Grundlehren der Mathematischen Wissenschaften [Fundamental Principles of Mathematical Sciences, p.552 ,
DOI : 10.1007/978-3-319-00227-9
URL : https://hal.archives-ouvertes.fr/hal-00929960
Nonasymptotic mixing of the MALA algorithm, IMA Journal of Numerical Analysis, vol.33, issue.1, pp.80-110, 1093. ,
DOI : 10.1093/imanum/drs003
Pathwise accuracy and ergodicity of metropolized integrators for SDEs, Communications on Pure and Applied Mathematics, vol.106, issue.3, pp.655-696, 2010. ,
DOI : 10.1017/CBO9780511526237
Central limit theorems for additive functionals of ergodic Markov diffusions processes, ALEA 9, pp.337-382, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00585271
MCMC methods for functions: modifying old algorithms to make them faster, In: Statist. Sci, vol.283, pp.424-446, 2013. ,
Theoretical guarantees for approximate sampling from smooth and log-concave densities, In: Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.793, pp.651-676, 2017. ,
High-dimensional Bayesian inference via the Unadjusted Langevin Algorithm, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01304430
Nonasymptotic convergence analysis for the unadjusted Langevin algorithm, The Annals of Applied Probability, vol.27, issue.3, pp.1551-1587, 2017. ,
DOI : 10.1214/16-AAP1238
URL : https://hal.archives-ouvertes.fr/hal-01176132
Sparse regression learning by aggregation and Langevin Monte-Carlo, Journal of Computer and System Sciences, vol.78, issue.5, pp.1423-1443, 2012. ,
DOI : 10.1016/j.jcss.2011.12.023
URL : https://hal.archives-ouvertes.fr/hal-00773553
Reflection couplings and contraction rates for diffusions, pp.1-36, 2015. ,
Stochastic differential equations and applications. Courier Corporation, 2012. ,
Representations of knowledge in complex systems With discussion and a reply by the authors, In: J. Roy. Statist. Soc. Ser. B, vol.564, pp.549-603, 1994. ,
A Liapounov bound for solutions of the Poisson equation, Ann. Probab, vol.24, issue.2, pp.916-931, 1996. ,
Measuring Sample Quality with Diffusions, 2016. ,
Tutorial in pattern theory, Division of Applied Mathematics, 1983. ,
Elliptic partial differential equations of second order, 2015. ,
Numerical approximations of stochastic differential equations with non-globally Lipschitz continuous coefficients, Memoirs of the American Mathematical Society, vol.236, issue.1112, 1112. ,
DOI : 10.1090/memo/1112
Strong and weak divergence in finite time of Euler's method for stochastic differential equations with non-globally Lipschitz continuous coefficients, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.316, issue.3, p.2130, 2011. ,
DOI : 10.1016/j.jmaa.2005.04.052
Strong convergence of an explicit numerical method for SDEs with nonglobally Lipschitz continuous coefficients, The Annals of Applied Probability, vol.22, issue.4, pp.1611-1641, 2012. ,
DOI : 10.1214/11-AAP803
Strong Convergence of Euler-Type Methods for Nonlinear Stochastic Differential Equations, SIAM Journal on Numerical Analysis, vol.40, issue.3, 2002. ,
DOI : 10.1137/S0036142901389530
Stochastic Differential Equations and Diffusion Processes. North-Holland Mathematical Library, 1989. ,
Geometric ergodicity of Metropolis algorithms, Stochastic Processes and their Applications 85, pp.341-361, 2000. ,
Weak backward error analysis for overdamped Langevin processes, IMA Journal of Numerical Analysis, vol.35, issue.2, pp.583-614, 1093. ,
DOI : 10.1093/imanum/dru016
URL : https://hal.archives-ouvertes.fr/hal-00905684
On Milstein approximations with varying coefficients: the case of super-linear diffusion coefficients, 2016. ,
On tamed milstein schemes of SDEs driven by Lévy noise, Discrete and Continuous Dynamical Systems - Series B 22, pp.421-463, 2017. ,
Brownian Motion and Stochastic Calculus. Graduate Texts in Mathematics, 1991. ,
Information theory and statistics. Reprint of the second (1968) edition, p.399, 1997. ,
Brownian motion, martingales, and stochastic calculus, 2016. ,
DOI : 10.1007/978-3-319-31089-3
Kinetic energy choice in Hamiltonian/hybrid Monte Carlo, 2017. ,
An adaptive Euler-Maruyama scheme for SDEs: convergence and stability, IMA Journal of Numerical Analysis, vol.27, issue.3, pp.479-506, 2007. ,
DOI : 10.1093/imanum/drl032
URL : http://arxiv.org/pdf/math/0601029
Statistics of random Processes: I. general Theory, 2013. ,
Partial differential equations and stochastic methods in molecular dynamics, Acta Numerica, vol.25, pp.681-880, 2016. ,
Ergodicity for SDEs and approximations: locally Lipschitz vector fields and degenerate noise, Stochastic Process. Appl. 101, pp.185-232, 2002. ,
DOI : 10.1016/S0304-4149(02)00150-3
Convergence of Numerical Time-Averaging and Stationary Measures via Poisson Equations, SIAM Journal on Numerical Analysis, vol.48, issue.2, 2010. ,
DOI : 10.1137/090770527
URL : http://arxiv.org/pdf/0908.4450.pdf
Stability of Markovian processes. III. Foster- Lyapunov criteria for continuous-time processes, In: Adv. in Appl. Probab, vol.253, pp.518-548, 1993. ,
Correlation functions and computer simulations, Nuclear Physics B, vol.180, pp.378-384, 1981. ,
On the Poisson equation and diffusion approximation 3, The Annals of Probability, vol.33, issue.3, pp.1061-1085, 2001. ,
DOI : 10.1214/009117905000000062
URL : http://doi.org/10.1214/009117905000000062
Exponential Convergence of Langevin Distributions and Their Discrete Approximations, Bernoulli, vol.2, issue.4, pp.341-363, 1996. ,
DOI : 10.2307/3318418
A note on tamed Euler approximations, Electronic Communications in Probability, vol.18, issue.0, 2013. ,
DOI : 10.1214/ECP.v18-2824
URL : http://doi.org/10.1214/ecp.v18-2824
Optimal transport : old and new. Grundlehren der mathematischen Wissenschaften, 2009. ,
The tamed Milstein method for commutative stochastic differential equations with non-globally Lipschitz continuous coefficients, Journal of Difference Equations and Applications, vol.19, issue.3, pp.466-490, 2013. ,
DOI : 10.1007/BF02846028
