Data supporting the research in this paper is available from http Cylindrical algebraic decomposition I: The basic algorithm, SIAM J. Comput, vol.13, issue.4, pp.865-877, 1984. ,
Bertini: Software for numerical algebraic geometry, pp.10-7274 ,
Emergent Properties of Networks of Biological Signaling Pathways, Science, vol.283, issue.5400, pp.381-387, 1999. ,
DOI : 10.1126/science.283.5400.381
Triangular decomposition of semi-algebraic systems, Journal of Symbolic Computation, vol.49, pp.3-26, 2013. ,
DOI : 10.1016/j.jsc.2011.12.014
Computing cylindrical algebraic decomposition via triangular decomposition, Proceedings of the 2009 international symposium on Symbolic and algebraic computation, ISSAC '09, pp.95-102, 2009. ,
DOI : 10.1145/1576702.1576718
URL : http://www.csd.uwo.ca/~moreno//Publications/Chen.Moreno-Maza.Xia.Yang-ISSAC-2009.pdf
Identifying parameter regions for multistationarity, PLOS Computational Biology, vol.24, issue.2, 2017. ,
DOI : 10.1371/journal.pcbi.1005751.s001
URL : https://doi.org/10.1371/journal.pcbi.1005751
Multistationarity in the activation of a MAPK: Parametrizing the relevant region in parameter space, Mathematical Biosciences, vol.211, issue.1, pp.105-136, 2008. ,
DOI : 10.1016/j.mbs.2007.10.004
Catalytic constants enable the emergence of bistability in dual phosphorylation, Journal of The Royal Society Interface, vol.276, issue.12, p.2014 ,
DOI : 10.1111/j.1742-4658.2009.07027.x
Toric dynamical systems, Journal of Symbolic Computation, vol.44, issue.11, pp.1551-1565, 2009. ,
DOI : 10.1016/j.jsc.2008.08.006
URL : https://doi.org/10.1016/j.jsc.2008.08.006
REDLOG, ACM SIGSAM Bulletin, vol.31, issue.2, pp.2-9, 1997. ,
DOI : 10.1145/261320.261324
Improving the Use of Equational Constraints in Cylindrical Algebraic Decomposition, Proceedings of the 2015 ACM on International Symposium on Symbolic and Algebraic Computation, ISSAC '15, pp.165-172, 2015. ,
DOI : 10.1109/SYNASC.2014.15
The complexity of cylindrical algebraic decomposition with respect to polynomial degre, Proceedings of the CASC 2016, pp.172-192, 2016. ,
Chemical reaction network structure and the stability of complex isothermal reactors???I. The deficiency zero and deficiency one theorems, Chemical Engineering Science, vol.42, issue.10, pp.2229-226837, 1987. ,
DOI : 10.1016/0009-2509(87)80099-4
Algebraic Systems Biology: A Case Study for the Wnt Pathway, Bulletin of Mathematical Biology, vol.25, issue.1, pp.21-51, 2016. ,
DOI : 10.1145/317275.317286
Testing Stability by Quantifier Elimination, Journal of Symbolic Computation, vol.24, issue.2, pp.161-187, 1997. ,
DOI : 10.1006/jsco.1997.0121
A note on " MAPK networks and their capacity for multistationarity due to toric steady states, 2014. ,
A Survey of Methods for Deciding Whether a Reaction Network is Multistationary, Mathematical Modelling of Natural Phenomena, vol.12, issue.1, pp.47-67, 2015. ,
DOI : 10.1137/120873388
BioModels Database: An enhanced, curated and annotated resource for published quantitative kinetic models, BMC Systems Biology, vol.4, issue.1, p.92, 2010. ,
DOI : 10.1186/1752-0509-4-92
URL : https://bmcsystbiol.biomedcentral.com/track/pdf/10.1186/1752-0509-4-92?site=bmcsystbiol.biomedcentral.com
Signaling switches and bistability arising from multisite phosphorylation in protein kinase cascades, The Journal of Cell Biology, vol.71, issue.3, pp.353-359, 2004. ,
DOI : 10.1074/jbc.M103369200
URL : http://jcb.rupress.org/content/jcb/164/3/353.full.pdf
The structure of MESSI biological systems, 2016. ,
MAPK's networks and their capacity for multistationarity due to toric steady states, Math. Biosci, vol.262, pp.125-162, 2015. ,
Determining all extreme semi-positive conservation relations in chemical reaction systems: a test criterion for conservativity, J. Chem. Soc., Faraday Trans., vol.22, issue.16, pp.2561-2566, 1991. ,
DOI : 10.1016/0303-2647(88)90047-0
Introduction to numerical algebraic geometry, Solving Polynomial Equations: Foundations, Algorithms, and Applications, pp.301-337, 2005. ,
DOI : 10.1007/3-540-27357-3_8
URL : http://www.math.tamu.edu/%7Ejhauenst/preprints/hauenstein_thesis.pdf
Elimination Methods, 2000. ,
DOI : 10.1007/978-3-7091-6202-6
URL : https://hal.archives-ouvertes.fr/hal-01573183
Stability analysis of biological systems with real solution classification, Proceedings of the 2005 international symposium on Symbolic and algebraic computation , ISSAC '05, pp.354-361, 2005. ,
DOI : 10.1145/1073884.1073933
URL : https://hal.archives-ouvertes.fr/hal-01486880
Quantifier Elimination for Real Algebra -- the Quadratic Case and Beyond, Applicable Algebra in Engineering, Communication and Computing, vol.8, issue.2, pp.85-101, 1997. ,
DOI : 10.1007/s002000050055
URL : http://www.fmi.uni-passau.de/~redlog/paper/quadqe1.ps.Z
Complexity in Biological Signaling Systems, Science, vol.284, issue.5411, pp.92-98, 1999. ,
DOI : 10.1126/science.284.5411.92
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3773983/pdf
