Tensor Decompositions for Learning Latent Variable Models (A Survey for ALT), pp.19-38, 2015. ,
DOI : 10.1137/S0895479899352045
Tensor decomposition and homotopy continuation. Differential Geometry and its Applications, 2017. ,
DOI : 10.1016/j.difgeo.2017.07.009
URL : https://hal.archives-ouvertes.fr/hal-01250398
General tensor decomposition, moment matrices and applications, Journal of Symbolic Computation, vol.52, pp.51-71, 2013. ,
DOI : 10.1016/j.jsc.2012.05.012
URL : https://hal.archives-ouvertes.fr/inria-00590965
Symmetric tensor decomposition. Linear Algebra and Applications, pp.11-121851, 2010. ,
DOI : 10.1016/j.laa.2010.06.046
URL : https://hal.archives-ouvertes.fr/inria-00355713
Handbook of Blind Source Separation: Independent component analysis and applications. Academic press, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00460653
IntroductionàIntroduction`Introductionà la résolution des systèmes polynomiaux, Mathématiques et Applications, vol.59, 2007. ,
Structured low rank decomposition of multivariate Hankel matrices, Linear Algebra and its Applications, 2017. ,
DOI : 10.1016/j.laa.2017.04.015
URL : https://hal.archives-ouvertes.fr/hal-01440063
Robust determination of the fiber orientation distribution in diffusion mri: Non-negativity constrained superresolved spherical deconvolution, NI, vol.35, issue.4, pp.1459-1472, 2007. ,
Kruskal's Permutation Lemma and the Identification of CANDECOMP/PARAFAC and Bilinear Models with Constant Modulus Constraints, IEEE Transactions on Signal Processing, vol.52, issue.9, pp.2625-2636, 2004. ,
DOI : 10.1109/TSP.2004.832022
Tensors: Geometry and Applications. Graduate studies in mathematics, 2011. ,
DOI : 10.1090/gsm/128
Tensor-based techniques for the blind separation of DS???CDMA signals, Signal Processing, vol.87, issue.2, pp.322-336, 2007. ,
DOI : 10.1016/j.sigpro.2005.12.015
Détection des croisements de fibre en IRM de diffusion par décomposition de tenseur : Approche analytique, Reconnaissance de Formes et Intelligence Artificielle, 2014. ,
Isolated points, duality and residues, Journal of Pure and Applied Algebra, vol.117, issue.118, pp.469-493, 1996. ,
DOI : 10.1016/S0022-4049(97)00023-6
URL : https://hal.archives-ouvertes.fr/inria-00125278
Polynomial-exponential decomposition from moments. Found, Comput. Math, 2016. ,
DOI : 10.1007/s10208-017-9372-x
URL : https://hal.archives-ouvertes.fr/hal-01367730
A Short Proof that Phylogenetic Tree Reconstruction by Maximum Likelihood Is Hard, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.3, issue.1, 2006. ,
DOI : 10.1109/TCBB.2006.4
URL : http://arxiv.org/pdf/math/0504378v1.pdf
Tensorial resolution: A direct trilinear decomposition, Journal of Chemometrics, vol.3, issue.1, pp.29-45, 1990. ,
DOI : 10.1016/0584-8539(88)80003-5
Blind PARAFAC receivers for DS-CDMA systems, IEEE Transactions on Signal Processing, vol.48, issue.3, pp.810-823, 2000. ,
DOI : 10.1109/78.824675
URL : http://spincom.ece.umn.edu/papers/journal/2000/SP_Parafac.pdf
Multi-way analysis: applications in the chemical sciences, 2005. ,
DOI : 10.1002/0470012110
Symmetric positive semi-definite cartesian tensor fiber orientation distributions (ct-fod), Medical Image Analysis Journal, vol.16, issue.6, pp.1121-1129, 2012. ,
