RiskInDroid: Machine Learning-Based Risk Analysis on Android - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gabriel Claudiu Georgiu
  • Fonction : Auteur
  • PersonId : 1023778
Risk analysis on Android is aimed at providing metrics to users for evaluating the trustworthiness of the apps they are going to install. Most of current proposals calculate a risk value according to the permissions required by the app through probabilistic functions that often provide unreliable risk values. To overcome such limitations, this paper presents RiskInDroid, a tool for risk analysis of Android apps based on machine learning techniques. Extensive empirical assessments carried out on more than 112 K apps and 6 K malware samples indicate that RiskInDroid outperforms probabilistic methods in terms of precision and reliability.
449885_1_En_36_Chapter.pdf (520.63 Ko) Télécharger le fichier
hal-01648990 , version 1 (27-11-2017)
Paternité
Alessio Merlo, Gabriel Claudiu Georgiu. RiskInDroid: Machine Learning-Based Risk Analysis on Android. 32th IFIP International Conference on ICT Systems Security and Privacy Protection (SEC), May 2017, Rome, Italy. pp.538-552, ⟨10.1007/978-3-319-58469-0_36⟩. ⟨hal-01648990⟩
410 Consultations
176 Téléchargements
