Runtime Firmware Product Lines Using TPM2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Runtime firmware product lines enable the generation of unified firmware images, i.e., a single firmware with several features can be used on several models. The device itself “decides” whether to unlock a feature or not. However, an attacker could alter their model and upgrade it to a higher-level model. In this paper, we propose an approach for secure runtime firmware product lines. Unified firmware images can be provisioned to a whole series of products while preventing unauthorized feature activation. Our approach is based on a Trusted Platform Module (TPM) 2.0, acting as security anchor using several new TPM 2.0 functionalities. The feasibility is shown in a proof-of-concept implementation.
449885_1_En_17_Chapter.pdf (890.06 Ko) Télécharger le fichier
hal-01649005 , version 1 (27-11-2017)
Paternité
Andreas Fuchs, Christoph Krauss, Jürgen Repp. Runtime Firmware Product Lines Using TPM2.0. 32th IFIP International Conference on ICT Systems Security and Privacy Protection (SEC), May 2017, Rome, Italy. pp.248-261, ⟨10.1007/978-3-319-58469-0_17⟩. ⟨hal-01649005⟩
244 Consultations
305 Téléchargements
