Jasmin: High-Assurance and High-Speed Cryptography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jasmin is a framework for developing high-speed and high-assurance cryptographic software. The framework is structured around the Jasmin programming language and its compiler. The language is designed for enhancing portability of programs and for simplifying verification tasks. The compiler is designed to achieve predictability and efficiency of the output code (currently limited to x64 platforms), and is formally verified in the Coq proof assistant. Using the super-cop framework, we evaluate the Jasmin compiler on representative cryptographic routines and conclude that the code generated by the compiler is as efficient as fast, hand-crafted, implementations. Moreover , the framework includes highly automated tools for proving memory safety and constant-time security (for protecting against cache-based timing attacks). We also demonstrate the effectiveness of the verification tools on a large set of cryptographic routines.
main.pdf (750.89 Ko) Télécharger le fichier
hal-01649140 , version 1 (27-11-2017)
  • HAL Id : hal-01649140 , version 1
José Bacelar Almeida, Manuel Barbosa, Gilles Barthe, Arthur Blot, Benjamin Grégoire, et al.. Jasmin: High-Assurance and High-Speed Cryptography. CCS 2017 - Proceedings of the 2017 ACM SIGSAC Conference on Computer and Communications Security, Oct 2017, Dallas, United States. pp.1-17. ⟨hal-01649140⟩
1381 Consultations
691 Téléchargements
