Finite-time estimation for linear time-delay systems via homogeneous method - Archive ouverte HAL Access content directly
Journal Articles International Journal of Control Year : 2019
Gang Zheng
This paper presents a finite-time observer for linear time-delay systems with commensurate delay. Unlike the existing observers in the literature which converge asymptotically, the proposed observer provides a finite-time estimation. This is realized by using the well-known homogeneous technique, and the results are also extended to investigate the estimation problem for linear time-delay systems with unknown inputs. Simulation results are presented in order to illustrate the feasibility of the proposed method.
Hal.pdf (437.48 Ko) Télécharger le fichier
Dates and versions
hal-01649434 , version 1 (27-11-2017)
Identifiers
Cite
Gang Zheng, Haoping Wang. Finite-time estimation for linear time-delay systems via homogeneous method. International Journal of Control, 2019, 92 (6), pp.1252-1263. ⟨10.1080/00207179.2017.1390255⟩. ⟨hal-01649434⟩
240 View
202 Download
Share
