New interface
Conference papers
Simulating the Risks from Aircraft Debris to the Public on the Ground
Arnaud Prouzeau 1, 2 Chris Johnson 3
2 ILDA - Interacting with Large Data
LRI - Laboratoire de Recherche en Informatique, Inria Saclay - Ile de France
Abstract : The International Civil Aviation Organisation (ICAO) identify an Airprox to be a situation in which, in the opinion of a pilot or air traffic services personnel, the distance between aircraft as well as their relative positions and speed have been such that the safety of the aircraft involved may have been compromised. These are relatively rare events but they must be reported and investigated in order to reduce future risks. Airprox investigations and similar studies into near-miss incidents focus on the risk to passengers and crew. They do not consider the impact of debris. This raises concerns when, for example, the Bijlmermeer crash led to the deaths of 39 people on the ground. This paper presents a system that was developed to simulate the risks from aircraft debris on ground-based infrastructures. The system was developed and validated with help from Airprox investigators. To this end, a User Centered Design process was applied; analysing the activities and needs of potential users from two European investigation agencies. The following pages present the key design decisions, provide insights into the development process and identify limitations with our existing system. The closing sections identify further applications of this approach and suggest areas for further work.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01649890
Contributor : Arnaud Prouzeau Connect in order to contact the contributor
Submitted on : Tuesday, November 28, 2017 - 12:20:54 PM
Last modification on : Tuesday, October 25, 2022 - 4:22:24 PM
File
prouzeauV2.pdf
Identifiers
Citation
Arnaud Prouzeau, Chris Johnson. Simulating the Risks from Aircraft Debris to the Public on the Ground. ATACCS 2015 - 5th International Conference on Application and Theory of Automation in Command and Control Systems, Sep 2015, Toulouse, France. ⟨10.1145/2899361.2899372⟩. ⟨hal-01649890⟩
Share
Metrics
Record views
144
Files downloads
171
