On the importance of considering physical attacks when implementing lightweight cryptography, NIST Lightweight Cryptography Workshop 2016, 2016. ,
URL : https://hal.archives-ouvertes.fr/cea-01436006
When Clocks Fail: On Critical Paths and Clock Faults, CARDIS 2010, pp.182-193, 2010. ,
DOI : 10.1007/978-3-642-12510-2_13
URL : https://hal.archives-ouvertes.fr/emse-00474337
Block Ciphers ??? Focus on the Linear Layer (feat. PRIDE), CRYPTO 2014, Part I. LNCS, pp.57-76, 2014. ,
DOI : 10.1007/978-3-662-44371-2_4
Midori: A Block Cipher for Low Energy, ASIACRYPT 2015 -Part II. LNCS, pp.411-436, 2015. ,
DOI : 10.1007/978-3-662-48800-3_17
SIMON and SPECK: Block ciphers for the internet of things, Cryptology ePrint Archive, vol.585, p.585, 2015. ,
CUBE Cipher: A Family of Quasi-Involutive Block Ciphers Easy to Mask, Codes, Cryptology, and Information Security: First International Conference, C2SI 2015 Proceedings -In Honor of Thierry Berger, pp.89-105978, 2015. ,
DOI : 10.1007/978-3-319-18681-8_8
URL : https://hal.archives-ouvertes.fr/hal-01199224
Differential fault analysis of secret key cryptosystems, CRYPTO'97, pp.513-525, 1997. ,
DOI : 10.1007/BFb0052259
URL : http://www.cs.technion.ac.il/users/wwwb/cgi-bin/tr-get.cgi/1997/CS/CS0910.revised.ps
Fides: Lightweight Authenticated Cipher with Side-Channel Resistance for Constrained Hardware, Cryptographic Hardware and Embedded Systems, CHES 2013. Lecture notes in computer science, pp.142-158, 2013. ,
DOI : 10.1007/978-3-642-40349-1_9
URL : http://eprint.iacr.org/2015/424.pdf
Fault Based Cryptanalysis of the Advanced Encryption Standard (AES), FC 2003, pp.162-181 ,
DOI : 10.1007/978-3-540-45126-6_12
On the importance of checking cryptographic protocols for faults (extended abstract), EUROCRYPT'97, pp.37-51, 1997. ,
PRINCE -A low-latency block cipher for pervasive computing applications -extended abstract, ASIACRYPT 2012, pp.208-225, 2012. ,
DOI : 10.1007/978-3-642-34961-4_14
URL : http://orbit.dtu.dk/en/publications/prince--a-lowlatency-block-cipher-for-pervasive-computing-applications-extended-abstract(f7c39395-2294-475d-8fe4-102655401c00).html
Adjusting laser injections for fully controlled faults Constructive Side-Channel Analysis and Secure Design, Lecture Notes in Computer Science, pp.229-242, 2014. ,
DOI : 10.1007/978-3-319-10175-0_16
Electromagnetic Transient Faults Injection on a Hardware and a Software Implementations of AES, 2012 Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.7-15, 2012. ,
DOI : 10.1109/FDTC.2012.15
URL : https://hal.archives-ouvertes.fr/emse-00742639
Block ciphers that are easier to mask: How far can we go? Cryptology ePrint Archive, p.369, 2013. ,
KLEIN: A New Family of Lightweight Block Ciphers, pp.1-18978, 2011. ,
DOI : 10.1007/978-3-642-25286-0_1
LS-Designs: Bitslice Encryption for Efficient Masked Software Implementations, FSE 2014, pp.18-37, 2015. ,
DOI : 10.1007/978-3-662-46706-0_2
URL : https://hal.archives-ouvertes.fr/hal-01093491
SCREAM, Side-Channel Resistant Authenticated Encryption with Masking, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01093512
Fault Injection Resilience, 2010 Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.51-65, 2010. ,
DOI : 10.1109/FDTC.2010.15
URL : https://hal.archives-ouvertes.fr/hal-00482194
The LED Block Cipher, CHES 2011, 2011. ,
DOI : 10.1007/978-3-642-23951-9_22
Scream: A Software-Efficient Stream Cipher, pp.195-209, 2002. ,
DOI : 10.1007/3-540-45661-9_15
PRINTcipher: A Block Cipher for IC-Printing, CHES 2010, pp.16-32, 2010. ,
DOI : 10.1007/978-3-642-15031-9_2
A First DFA on PRIDE: From Theory to Practice, Proc. 11th International Conference on Risks and Security of Internet and Systems, 2016. ,
DOI : 10.1007/978-3-319-17533-1_15
URL : https://hal.archives-ouvertes.fr/cea-01435998
Inverting the Final Exponentiation of Tate Pairings on Ordinary Elliptic Curves Using Faults, CHES 2013, pp.365-382, 2013. ,
DOI : 10.1007/978-3-642-40349-1_21
Tweakable Block Ciphers, Lecture Notes in Computer Science, vol.2442, pp.31-46, 2002. ,
DOI : 10.1007/3-540-45708-9_3
URL : https://link.springer.com/content/pdf/10.1007%2Fs00145-010-9073-y.pdf
Tweakable Block Ciphers, Journal of Cryptology, vol.12, issue.11, pp.588-613, 2011. ,
DOI : 10.1007/3-540-68697-5_24
Using SAT Solving to Improve Differential Fault Analysis of Trivium, Communications in Computer and Information Science, vol.139, issue.1-3, pp.62-71, 2011. ,
DOI : 10.1007/978-3-540-68351-3_1
Lightweight Fault Attack Resistance in Software Using Intra-instruction Redundancy, 2016. ,
DOI : 10.1145/967900.968073
Picaro ? a block cipher allowing efficient higherorder side-channel resistance, Applied Cryptography and Network Security: 10th International Conference, ACNS 2012, pp.311-328978, 2012. ,
DOI : 10.1007/978-3-642-31284-7_19
Implantation et optimisation des primitives cryptographiques, 2001. ,
Recursive diffusion layers for block ciphers and hash functions Fast Software Encryption: 19th International Workshop Revised Selected Papers, pp.385-401978, 2012. ,
DOI : 10.1007/978-3-642-34047-5_22
Information-Theoretic Approach to Optimal Differential Fault Analysis, IEEE Transactions on Information Forensics and Security, vol.7, issue.1, pp.109-120, 2012. ,
DOI : 10.1109/TIFS.2011.2174984
Semi-invasive attacks -A new approach to hardware security analysis, 2005. ,
Optical Fault Induction Attacks, CHES 2002, pp.2-12 ,
DOI : 10.1007/3-540-36400-5_2
Differential Fault Attack on the PRINCE Block Cipher, Cryptology ePrint Archive, p.43043, 2013. ,
DOI : 10.1007/978-3-642-40392-7_4
URL : http://eprint.iacr.org/2013/043.pdf
Nonlinear Invariant Attack, ASIACRYPT 2016 -Part II, pp.3-33, 2016. ,
DOI : 10.1007/3-540-69710-1_2
Differential Fault Analysis on the Families of SIMON and SPECK Ciphers, 2014 Workshop on Fault Diagnosis and Tolerance in Cryptography, p.267, 2014. ,
DOI : 10.1109/FDTC.2014.14
Improved side channel cube attacks on PRESENT. Cryptology ePrint Archive, Report, vol.2011165, p.165, 2011. ,
