Methodological Approach for Identifying Mechanisms in ICT4D: A Critical Realism Perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hans Olav Omland
  • Fonction : Auteur
  • PersonId : 1024000
Devinder Thapa
  • Fonction : Auteur
  • PersonId : 1021155
The ontological questions ‘What is ICT?’ and ‘What is development?’ are described and documented in literature. Similarly, methodological approaches for understanding how ICT leads to development or for measuring the impact of ICT are described. However, explaining ‘why’ ICT works or not in the contexts of developing countries needs further investigation. We propose a critical realism based methodological approach for answering the above mentioned ‘why’-question. The core of a critical realism based approach is to identify the underlying mechanism(s) that may explain a phenomenon of why ICT leads to development. We demonstrate the proposed methodology through applying it on a case in an ICT4D context from Nepal.
450518_1_En_16_Chapter.pdf (304.42 Ko) Télécharger le fichier
hal-01650109 , version 1 (28-11-2017)
Paternité
Hans Olav Omland, Devinder Thapa. Methodological Approach for Identifying Mechanisms in ICT4D: A Critical Realism Perspective. 14th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2017, Yogyakarta, Indonesia. pp.182-193, ⟨10.1007/978-3-319-59111-7_16⟩. ⟨hal-01650109⟩
99 Consultations
192 Téléchargements
