Combining Free choice and Time in Petri Nets
Time Petri nets (TPNs) are a classical extension of Petri nets with timing
constraints attached to transitions, for which most verification problems are un-
decidable. We consider TPNs under an urgent semantics with multiple enablings
of transitions (frequently called ”multi-server semantics”).
We focus on a structural subclass of unbounded TPNs, where the underlying
untimed net is free-choice, and show that it enjoys nice properties in the timed
setting under multi-server semantics. Indeed, for this class of TPNs, several
decision problems can be brought back to an untimed setting. In particular, we
show that the questions of firability (whether a chosen transition can fire), and
termination (whether the net has a non-terminating run) are decidable.
Next, we consider the problem of robustness under guard enlargement and
guard shrinking, i.e., whether a given property is preserved even if the system
is implemented on an architecture with imprecise time measurement. There are
several ways to model such imprecision. The first one is to consider the original
model in which all guards are enlarged, to model possible clocks drifts. It is
also frequent in the literature to model imprecision with guards shrinking, to
encompass delays or advance in guards triggering.
For unbounded free-choice TPNs with a multi-server semantics, we show de-
cidability of robustness of firability and of termination under both guard enlarge-
ment and shrinking. Up to our knowledge, this is the first decidability result for
robustness in unbounded nets. Closely-related problems such as decidability of
coverability and boundedness in free-choice TPNS and the associated robustness
questions are still open issues.
