Frequency Domain Forecasting Approach for Latency Reduction in Direct Human-Computer Interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The problem of latency reduction in direct human-computer interaction is considered and formulated as a trajectory prediction problem. To solve the problem, the predictor is constructed as a frequency-domain approximation of the non-casual ideal predictor. This approximation can be computed analytically, or obtained as an optimization task. An adaptive modification of the forecasting algorithm is proposed taking into account possible variations in user behavior. Experimental results illustrate the applicability of the proposed solution.
FreqPrediction_cdc17_final.pdf (310.29 Ko) Télécharger le fichier
hal-01651329 , version 1 (28-11-2017)
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Géry Casiez. Frequency Domain Forecasting Approach for Latency Reduction in Direct Human-Computer Interaction. CDC 2017 - 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. pp.2623-2628, ⟨10.1109/CDC.2017.8264040⟩. ⟨hal-01651329⟩
382 Consultations
259 Téléchargements
