The modern call center: A multi-disciplinary perspective on operations management research, pp.665-688, 2007. ,
Regular Functions and Cost Register Automata, 2013 28th Annual ACM/IEEE Symposium on Logic in Computer Science, pp.13-22, 2013. ,
DOI : 10.1109/LICS.2013.65
URL : http://www.cis.upenn.edu/%7Elorisdan/images/arxivsub.pdf
Regular Programming for Quantitative Properties of Data Streams, Programming Languages and Systems -25th European Symposium on Programming, ESOP 2016, pp.15-40, 2016. ,
DOI : 10.1145/2728606.2728648
Systematic Derivation of Bounds and Glue Constraints for Time-Series Constraints, LNCS, vol.21, issue.1, pp.13-29, 2016. ,
DOI : 10.1007/978-3-642-33558-7_40
URL : https://hal.archives-ouvertes.fr/hal-01370317
Mats Carlsson, Pierre Flener, María Andreína Francisco Rodríguez, Justin Pearson, and Helmut Simonis . Global constraint catalog, volume ii, time-series constraints, 2016. ,
Time-Series Constraints: Improvements and Application in CP and MIP Contexts, CP-AI-OR 2016, pp.18-34, 2016. ,
DOI : 10.1007/978-3-319-33954-2_2
URL : https://hal.archives-ouvertes.fr/hal-01355262
Using finite transducers for describing and synthesising structural time-series constraints, Constraints, vol.38, issue.11, pp.22-40, 2015. ,
DOI : 10.1145/2103656.2103674
URL : https://hal.archives-ouvertes.fr/hal-01370322
Deriving Filtering Algorithms from Constraint Checkers, LNCS, vol.3258, pp.107-122, 2004. ,
DOI : 10.1007/978-3-540-30201-8_11
URL : http://eprints.sics.se/2346/01/SICS-T--2004-08--SE.pdf
Introducing global constraints in CHIP, Mathematical and Computer Modelling, vol.20, issue.12, pp.97-123, 1994. ,
DOI : 10.1016/0895-7177(94)90127-9
URL : https://hal.archives-ouvertes.fr/hal-00442810
Describing and Generating Solutions for the EDF Unit Commitment Problem with the ModelSeeker, CP 2013, pp.733-748, 2013. ,
DOI : 10.1007/978-3-642-40627-0_54
URL : https://hal.archives-ouvertes.fr/hal-00874326
Constraint Acquisition via Partial Queries, IJCAI 2013, p.7, 2013. ,
Learning Implied Global Constraints, IJCAI 2007, pp.50-55, 2007. ,
Among, Common and Disjoint Constraints, Recent Advances in Constraints , Joint ERCIM/CoLogNET International Workshop on Constraint Solving and Constraint Logic Programming, CSCLP 2005, pp.29-43, 2005. ,
DOI : 10.1023/A:1009894810205
Approximate Comparison of Functions Computed by Distance Automata, Theory of Computing Systems, vol.28, issue.3???4, pp.579-613, 2016. ,
DOI : 10.1007/3-540-07407-4_23
A Cost-Regular Based Hybrid Column Generation Approach, Constraints, vol.12, issue.4???5, pp.315-333, 2006. ,
DOI : 10.1007/s10732-006-6550-4
URL : https://hal.archives-ouvertes.fr/hal-00293562
Performance analysis through synthetic trace generation, 2000 IEEE International Symposium on Performance Analysis of Systems and Software. ISPASS (Cat. No.00EX422), pp.1-6, 2000. ,
DOI : 10.1109/ISPASS.2000.842273
URL : http://www.elis.ugent.be/~leeckhou/papers/ispass00.pdf
Template-based time series generation with loom, EDBT/ICDT Workshops 2016, 2016. ,
A Regular Language Membership Constraint for Finite Sequences of Variables, LNCS, vol.3258, pp.482-495, 2004. ,
DOI : 10.1007/978-3-540-30201-8_36
Learning Parameters for the Sequence Constraint from Solutions, CP 2016, pp.405-420, 2016. ,
DOI : 10.1007/s10601-008-9065-9
On the definition of a family of automata, Information and Control, vol.4, pp.245-270, 1961. ,
