New interface
Poster communications
Poster: Toward a Better Monitoring of Air Pollution using Mobile Wireless Sensor Networks
Abstract : Mobile wireless sensor networks (MWSN) are widely used for monitoring physical phenomena such as air pollution where the aim is usually to generate accurate pollution maps in real time. The generation of pollution maps can be performed using either sensor measurements or physical models which simulate the phenomenon of pollution dispersion. The combination of these two information sources, known as data assimilation, makes it possible to better monitor air pollution by correcting the simulations of physical models while relying on sensor measurements. The quality of data assimilation mainly depends on the number of measurements and their locations. A careful deployment of nodes is therefore necessary in order to get better pollution maps. In this ongoing work, we tackle the placement problem of pollution sensors and design a mixed integer programming model allowing to maximize the assimilation quality while ensuring the connectivity of the network. We perform some simulations on a dataset of the Lyon city, France in order to show the eeectiveness of our model regarding the quality of pollution coverage.
Document type :
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-01651734
Contributor : Ahmed Boubrima Connect in order to contact the contributor
Submitted on : Wednesday, November 29, 2017 - 7:05:22 PM
Last modification on : Tuesday, October 25, 2022 - 4:20:57 PM
File
Mobicom_Paper__HAL_.pdf
Identifiers
Citation
Ahmed Boubrima, Walid Bechkit, Hervé Rivano, Lionel Soulhac. Poster: Toward a Better Monitoring of Air Pollution using Mobile Wireless Sensor Networks. MobiCom 2017 - The 23rd Annual International Conference on Mobile Computing and Networking, Oct 2017, Utah, United States. , pp.1-3, 2017, ⟨10.1145/3117811.3131249⟩. ⟨hal-01651734⟩
Share
Metrics
Record views
493
Files downloads
292
