Conformance Checking Using Cost-Based Fitness Analysis, 2011 IEEE 15th International Enterprise Distributed Object Computing Conference, pp.55-64, 2011. ,
DOI : 10.1109/EDOC.2011.12
URL : http://wwwis.win.tue.nl/%7Ewvdaalst/publications/p630.pdf
Towards Robust Conformance Checking, Business Process Management Workshops, pp.122-133, 2011. ,
DOI : 10.1007/978-3-642-12186-9_15
URL : http://wwwis.win.tue.nl/%7Ewvdaalst/publications/p610.pdf
Verifiable agent interaction in abductive logic programming, ACM Transactions on Computational Logic, vol.9, issue.4, pp.1-2943, 2008. ,
DOI : 10.1145/1380572.1380578
A genetic algorithm for discovering process trees, 2012 IEEE Congress on Evolutionary Computation, pp.1-8, 2012. ,
DOI : 10.1109/CEC.2012.6256458
Quality Dimensions in Process Discovery: The Importance of Fitness, Precision, Generalization and Simplicity, International Journal of Cooperative Information Systems, vol.28, issue.01, pp.2014-2024 ,
DOI : 10.1007/BF00264611
Exploiting Inductive Logic Programming Techniques for Declarative Process Mining, chapter Transactions on Petri Nets and Other Models of Concurrency II: Special Issue on Concurrency in Process-Aware Information Systems, pp.278-29510, 2009. ,
Mining Constraints for Artful Processes, chapter Business Information Systems: 15th International Conference, BIS 2012, Proceedings, pp.11-23978, 2012. ,
DOI : 10.1007/978-3-642-30359-3_2
Aligning Event Logs and Declarative Process Models for Conformance Checking, Business Process Management, pp.82-97, 2012. ,
DOI : 10.1007/978-3-642-32885-5_6
Road traffic fine management process, pp.270-440 ,
Enhancing process mining results using domain knowledge ,
Repairing Process Models to Reflect Reality, Business process management, pp.229-245, 2012. ,
DOI : 10.1007/978-3-642-32885-5_19
Business process verification with constraint temporal answer set programming. Theory and Practice of Logic Programming, pp.641-65510, 2013. ,
Robust process discovery with artificial negative events, J. Mach. Learn. Res, vol.10, pp.1305-1340, 2009. ,
Process Discovery under Precedence Constraints, ACM Transactions on Knowledge Discovery from Data, vol.9, issue.4, pp.1-3239, 2015. ,
DOI : 10.1016/j.datak.2010.06.001
Applying Inductive Logic Programming to Process Mining, chapter Inductive Logic Programming, 17th International Conference, pp.132-146, 2007. ,
DOI : 10.1007/978-3-540-78469-2_16
Discovering blockstructured process models from event logs containing infrequent behaviour, Business Process Management Workshops, pp.66-78, 2014. ,
DOI : 10.1007/978-3-319-06257-0_6
User-guided discovery of declarative process models, 2011 IEEE Symposium on Computational Intelligence and Data Mining (CIDM), pp.192-199, 2011. ,
DOI : 10.1109/CIDM.2011.5949297
DECLARE: Full Support for Loosely-Structured Processes, 11th IEEE International Enterprise Distributed Object Computing Conference (EDOC 2007), pp.287-287, 2007. ,
DOI : 10.1109/EDOC.2007.14
URL : http://wwwis.win.tue.nl/~wvdaalst/publications/p419.pdf
Where Did I Misbehave? Diagnostic Information in Compliance Checking, Business Process Management, pp.262-278, 2012. ,
DOI : 10.1007/978-3-642-32885-5_21
URL : http://wwwis.win.tue.nl/~wvdaalst/publications/p682.pdf
Process discovery using prior knowledge, Service-Oriented Computing, pp.328-342, 2013. ,
Constraint checking for business process management, GI Jahrestagung, pp.4093-4103, 2009. ,
Process Mining -Data Science in Action, 2016. ,
Process Discovery Using Integer Linear Programming, chapter Applications and Theory of Petri Nets: 29th International Conference, PETRI NETS, Proceedings, pp.368-387, 2008. ,
