Abstract : In this work, the main physical characteristics of plane water sheets flowing under gravity and
surrounded by free air are experimentally investigated. By varying the mean flow rate through a 0.8 mm
× 100 mm nozzle, water sheets are produced over a range of Reynolds and Weber numbers between
210 to 1240 and 0.37 to 13.52, respectively. First, the sensitivity of the sheets shapes to a mass flow rate
variation is evidenced. For a sufficiently high flow rate, a liquid sheet forms with two rims bordering it.
These rims join after a certain length L c resulting in a triangle-like shape of the sheet. This characteristic
length is compared with a theoretical prediction given by a model valid for Re >>1. Furthermore,
some capillary waves forming a striped pattern are present at the sheet interface near the rims and are
propagating towards the central axis as the sheet falls. These waves are interpreted as the consequence
of the displacement of a high curvature gradient zone at the rim-sheet interface as suggested by their
stationary shape. The critical mass flow rate at which the sheet destabilization is systematically observed
is Q c = 0.056 kg.s −1 . It corresponds to a Weber number We ≈2.7, a value in line with the theoretical
one We_th = O(1) which usually indicates a sufficient condition to maintain a stable sheet. Such ruptures
are characterized by the appearance of expanding hole(s), predominantly in the lower half of the sheet.
The experimentally determined mean expansion velocity proved to be within ±20% of that provided
by the well-known Culick expression. As expected, when considering mass flow rates below the above
mentioned critical one, an intermittent regime of rupture is obtained characterized by the presence of
sheets, threadlines, jets or drops.
