A Formally Proved, Complete Algorithm for Path Resolution with Symbolic Links - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Formalized Reasoning Année : 2017
In the context of file systems like those of Unix, path resolution is the operation that given a character string denoting an access path, determines the target object (a file, a directory, etc.) designated by this path. This operation is not trivial because of the presence of symbolic links. Indeed, the presence of such links may induce infinite loops in the resolution process. We consider a path resolution algorithm that always terminates, detecting if it enters an infinite loop and reports a resolution failure in such a case. We propose a formal specification of path resolution and we formally prove that our algorithm terminates on any input, and is correct and complete with respect to our formal specification.
jfr7213.pdf (305.97 Ko) Télécharger le fichier
hal-01652148 , version 1 (30-11-2017)
  • HAL Id : hal-01652148 , version 1
Ran Chen, Martin Clochard, Claude Marché. A Formally Proved, Complete Algorithm for Path Resolution with Symbolic Links. Journal of Formalized Reasoning, 2017, 10 (1). ⟨hal-01652148⟩
168 Consultations
122 Téléchargements
