Clustering multivariate functional data in group-specific functional subspaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Statistics Année : 2020
With the emergence of numerical sensors in many aspects of every- day life, there is an increasing need in analyzing multivariate functional data. This work focuses on the clustering of such functional data, in order to ease their modeling and understanding. To this end, a novel clustering technique for multivariate functional data is presented. This method is based on a func- tional latent mixture model which fits the data in group-specific functional subspaces through a multivariate functional principal component analysis. A family of parsimonious models is obtained by constraining model parameters within and between groups. An EM algorithm is proposed for model inference and the choice of hyper-parameters is addressed through model selection. Nu- merical experiments on simulated datasets highlight the good performance of the proposed methodology compared to existing works. This algorithm is then applied to the analysis of the pollution in French cities for one year.
Multivariate-funHDDC.pdf (994.91 Ko) Télécharger le fichier
hal-01652467 , version 1 (30-11-2017)
hal-01652467 , version 2 (17-07-2018)
hal-01652467 , version 3 (11-10-2019)
Amandine Schmutz, Julien Jacques, Charles Bouveyron, Laurence Chèze, Pauline Martin. Clustering multivariate functional data in group-specific functional subspaces. Computational Statistics, 2020, 35 (3), pp.1101-1131. ⟨10.1007/s00180-020-00958-4⟩. ⟨hal-01652467v3⟩
1414 Consultations
2785 Téléchargements
