A new look at the statistical model identification, IEEE Transactions on Automatic Control, vol.9, pp.716-723, 1974. ,
DOI : 10.1007/978-1-4612-1694-0_16
Principal components for multivariate functional data, Computational Statistics & Data Analysis, vol.55, issue.9, pp.2619-263, 2011. ,
DOI : 10.1016/j.csda.2011.03.011
URL : http://repositorio.udesa.edu.ar/jspui/bitstream/10908/635/1/%5bP%5d%5bW%5dBarrendero-Justel-Svarc.pdf
Assessing a mixture model for clustering with the integrated completed likelihood, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.22, issue.7, pp.719-725, 2000. ,
DOI : 10.1109/34.865189
Minimal penalties for gaussian model selection. Probability theory and related fields 138, pp.33-73, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00141376
Model-based clustering of time series in group-specific functional subspaces, Advances in Data Analysis and Classification, vol.38, issue.2, pp.281-300, 2011. ,
DOI : 10.1016/j.patcog.2005.01.025
URL : https://hal.archives-ouvertes.fr/hal-00707054
The discriminative functional mixture model for a comparative analysis of bike sharing systems, The Annals of Applied Statistics, vol.9, issue.4, pp.1726-1760, 2015. ,
DOI : 10.1214/15-AOAS861
URL : https://hal.archives-ouvertes.fr/hal-01024186
The Scree Test For The Number Of Factors, Multivariate Behavioral Research, vol.1, issue.2, pp.245-276, 1966. ,
DOI : 10.1207/s15327906mbr0102_10
Multi-dimensional functional principal component analysis, Statistics and Computing, vol.20, issue.9, pp.1181-1192, 2016. ,
DOI : 10.1198/jcgs.2011.10122
Multivariate functional principal component analysis: A normalization approach, Statistica Sinica, vol.24, pp.1571-1596, 2014. ,
DOI : 10.5705/ss.2013.305
Functional clustering and identifying substructures of longitudinal data, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.1, issue.4, pp.679-699, 2007. ,
DOI : 10.1093/bioinformatics/17.9.763
URL : http://onlinelibrary.wiley.com/doi/10.1111/j.1467-9868.2007.00605.x/pdf
Maximum likelihood from incomplete data via the EM algorithm, Journal of the Royal Statistical Society, vol.39, issue.1, pp.1-38, 1977. ,
Curves discrimination: a nonparametric functional approach, Computational Statistics & Data Analysis, vol.44, issue.1-2, pp.161-173, 2003. ,
DOI : 10.1016/S0167-9473(03)00032-X
Multivariate functional principal component analysis for data observed on different (dimensional) domains Multivariate Functional Clustering for the Morphological Analysis of ECG Curves, Journal of the American Statistical Association Journal of the Royal Statistical Society, Series C (Applied Statistics), vol.62, issue.3, pp.401-418, 2013. ,
Funclust: A curves clustering method using functional random variables density approximation, Neurocomputing, vol.112, pp.164-171, 2013. ,
DOI : 10.1016/j.neucom.2012.11.042
URL : https://hal.archives-ouvertes.fr/hal-00628247
Functional data clustering: a survey Advances in Data Analysis and Classification, pp.231-255, 2014. ,
Model-based clustering for multivariate functional data, Computational Statistics & Data Analysis, vol.71, pp.92-106, 2014. ,
DOI : 10.1016/j.csda.2012.12.004
URL : https://hal.archives-ouvertes.fr/hal-00943732
Clustering for Sparsely Sampled Functional Data, Journal of the American Statistical Association, vol.98, issue.462, pp.397-408, 2003. ,
DOI : 10.1198/016214503000189
URL : http://www-rcf.usc.edu/~gareth/research/fclust.pdf
Functional Cluster Analysis via Orthonormalized Gaussian Basis Expansions and Its Application, Journal of Classification, vol.5, issue.3, pp.211-230, 2010. ,
DOI : 10.1007/978-1-4899-4473-3
The matrix cookbook, 2012. ,
Regression models for functional data by reproducing kernel Hilbert spaces methods, Journal of Statistical Planning and Inference, vol.137, issue.3, pp.829-840, 2007. ,
DOI : 10.1016/j.jspi.2006.06.011
R: A Language and Environment for Statistical Computing. R Foundation for Statistical Computing, 2017. ,
Functional data analysis Objective criteria for the evaluation of clustering methods, Journal of the American Statistical Association, vol.66, issue.336, pp.846-850, 1971. ,
Méthodes exploratoires d'analyse de données temporelles, Cahiers du Buro, pp.37-38, 1981. ,
Estimating the dimension of a model Clustering multivariate time-series data, The Annals of Statistics Journal of Chemometrics, vol.6, issue.19, pp.427-438, 1978. ,
Clustering Functional Data, Journal of Classification, vol.20, issue.1, pp.93-114, 2003. ,
DOI : 10.1007/s00357-003-0007-3
Crisp and fuzzy k-means clustering algorithms for multivariate functional data, Computational Statistics, vol.15, issue.3, pp.1-16, 2007. ,
DOI : 10.5183/jjscs1988.15.2_319
Clustering of functional data in a low-dimensional subspace, Advances in Data Analysis and Classification, vol.37, issue.3, pp.219-247, 2012. ,
DOI : 10.1137/1.9781611970128
Dimension-Reduced Clustering of Functional Data via Subspace Separation, Journal of Classification, vol.79, issue.2, pp.294-326, 2017. ,
DOI : 10.1016/j.csda.2014.05.010
Functional factorial <mml:math altimg="si9.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>K</mml:mi></mml:math>-means analysis, Computational Statistics & Data Analysis, vol.79, pp.133-148, 2014. ,
