Handbook Second Edition: Methods, Concepts, Case Studies and Standards in Business Process Modeling Notation, Future Strategies, 2012. ,
Classification of Domain-Specific BPMN Extensions, pp.42-57, 2014. ,
DOI : 10.1007/978-3-662-45501-2_4
URL : https://hal.archives-ouvertes.fr/hal-01281988
Evaluation of Data-Centric Process Modeling Approaches, 2011. ,
The Formalization of the Business Process Modeling Goals, Joint Proceedings of the BIR 2016 Workshops and Doctoral Consortium co-located with 14th International-Conference on Perspectives in Business Informatics Research, 2016. ,
DOI : 10.7250/csimq.2016-8.03
Business Process Management: Concepts, Languages, Architectures, 2012. ,
DOI : 10.1007/978-3-642-28616-2
The Difference Between Workflow and BPR ,
The Difference between Process Architecture and Process Modeling/Design (and why you should care), http://grahammcleod.typepad.com/files/ processarchitecturevsprocessmodelingmcleod.pdf 10. van Nuffel D., de Backer M.: Multi-abstraction layered business process modeling, Computers in Industry, vol.63, issue.2, pp.131-147, 2012. ,
Correctly Defined Concrete Syntax for Visual Modeling Languages, pp.111-125, 2006. ,
DOI : 10.1007/11880240_9
Model-Driven Software Engineering in Practice, Synthesis Lectures on Software Engineering, vol.1, issue.1, 2012. ,
DOI : 10.2200/S00441ED1V01Y201208SWE001
URL : https://hal.archives-ouvertes.fr/hal-00755006
Business Process Modeling: A Maturing Discipline? ,
Ontological evaluation of enterprise systems interoperability using ebXML, IEEE Transactions on Knowledge and Data Engineering, vol.17, issue.5, pp.713-725, 2005. ,
DOI : 10.1109/TKDE.2005.79
Integrated process modeling: An ontological evaluation, Information Systems, vol.25, issue.2, pp.73-87, 2000. ,
DOI : 10.1016/S0306-4379(00)00010-7
Sometimes Less is More: Are Process Modeling Languages Overly Complex?, 2007 Eleventh International IEEE EDOC Conference Workshop, pp.197-204, 2007. ,
DOI : 10.1109/EDOCW.2007.30
Business Process Modeling, Active Research Areas and Challenges, 2011. ,
Perspectives on Process Modeling, http://www.bptrends. com/point-of-view- perspectives-on-process-modeling ,
Process Model Abstraction: A Slider Approach, 2008 12th International IEEE Enterprise Distributed Object Computing Conference, pp.325-331, 2008. ,
DOI : 10.1109/EDOC.2008.17
URL : http://bpt.hpi.uni-potsdam.de/pub/Public/SergeySmirnov/ProcessModelAbstractionSliderApproach.pdf
Business process model abstraction: a definition, catalog, and survey, Distributed and Parallel Databases, pp.63-99, 2012. ,
DOI : 10.1007/s10619-010-7060-9
Configurable multi-perspective business process models, Information Systems, vol.36, issue.2, pp.313-340, 2011. ,
DOI : 10.1016/j.is.2010.07.001
Bridging the Gap between Business Models and Workflow Specifications International, Journal of Cooperative Information Systems, vol.13, issue.3, pp.51-69, 2004. ,
Transformation of BPEL Processes to EPCs ,
From Conceptual Process Models to Running Workflows: A Holistic Approach for the Configuration of Enterprise Systems ,
