Universal limits of substitution-closed permutation classes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the European Mathematical Society Année : 2020
We consider uniform random permutations in proper substitution-closed classes and study their limiting behavior in the sense of permutons. The limit depends on the generating series of the simple permutations in the class. Under a mild sufficient condition, the limit is an elementary one-parameter deformation of the limit of uniform separable permutations, previously identified as the Brownian separable permuton. This limiting object is therefore in some sense universal. We identify two other regimes with different limiting objects. The first one is degenerate; the second one is nontrivial and related to stable trees. These results are obtained thanks to a characterization of the convergence of random permutons through the convergence of their expected pattern densities. The limit of expected pattern densities is then computed by using the substitution tree encoding of permutations and performing singularity analysis on the tree series.
hal-01653572 , version 1 (01-12-2017)
Frédérique Bassino, Mathilde Bouvel, Valentin Féray, Lucas Gerin, Mickaël Maazoun, et al.. Universal limits of substitution-closed permutation classes. Journal of the European Mathematical Society, 2020, 22 (11), pp.3565-3639. ⟨10.4171/JEMS/993⟩. ⟨hal-01653572⟩
580 Consultations
0 Téléchargements
