Matrix formulae for Resultants and Discriminants of Bivariate Tensor-product Polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2020
The construction of optimal resultant formulae for polynomial systems is one of the main areas of research in computational algebraic geometry. However, most of the constructions are restricted to formulae for unmixed polynomial systems, that is, systems of polynomials which all have the same support. Such a condition is restrictive, since mixed systems of equations arise frequently in many problems. Nevertheless, resultant formulae for mixed polynomial systems is a very challenging problem. We present a square, Koszul-type, matrix, the determinant of which is the resultant of an arbitrary (mixed) bivariate tensor-product polynomial system. The formula generalizes the classical Sylvester matrix of two univariate polynomials, since it expresses a map of degree one, that is, the elements of the corresponding matrix are up to sign the coefficients of the input polynomials. Interestingly, the matrix expresses a primal-dual multiplication map, that is, the tensor product of a univariate multiplication map with a map expressing derivation in a dual space. In addition we prove an impossibility result which states that for tensor-product systems with more than two (affine) variables there are no universal degree-one formulae, unless the system is unmixed. Last but not least, we present applications of the new construction in the efficient computation of discriminants and mixed discriminants.
bmt-j-bivar.pdf (348.07 Ko) Télécharger le fichier
Format : Figure, Image
hal-01654263 , version 1 (03-12-2017)
Laurent Busé, Angelos Mantzaflaris, Elias Tsigaridas. Matrix formulae for Resultants and Discriminants of Bivariate Tensor-product Polynomials. Journal of Symbolic Computation, 2020, 98, pp.65-83. ⟨10.1016/j.jsc.2019.07.007⟩. ⟨hal-01654263⟩
688 Consultations
767 Téléchargements
