Periodicity in optimal hierarchical checkpointing schemes for adjoint computations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization Methods and Software Année : 2017
We reexamine the work of Aupy et al. on optimal algorithms for hierarchical adjoint computations , where two levels of memories are available. The previous optimal algorithm had a quadratic execution time. Here, with structural arguments, namely periodicity, on the optimal solution, we provide an optimal algorithm in constant time and space, with appropriate pre-processing. We also provide an asymptotically optimal algorithm for the online problem, when the adjoint chain size is not known beforehand. Again, these algorithms rely on the proof that the optimal solution for hierarchical adjoint computations is weakly periodic. We conjecture a closed-form formula for the period. Finally, we assess the convergence speed of the approximation ratio for the online problem through simulations.
main-revision.pdf (878.79 Ko) Télécharger le fichier
hal-01654632 , version 1 (04-12-2017)
Guillaume Aupy, Julien Herrmann. Periodicity in optimal hierarchical checkpointing schemes for adjoint computations. Optimization Methods and Software, 2017, 32 (3), pp.594-624. ⟨10.1080/10556788.2016.1230612⟩. ⟨hal-01654632⟩
347 Consultations
166 Téléchargements
