INDICES: Exploiting Edge Resources for Performance-aware Cloud-hosted Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite the known benefits of hosting cloud-based services, the longer and often unpredictable end-to-end network latencies between the end user and the cloud can be detrimental to the response time requirements of the interactive cloud-hosted applications. Existing efforts that exploit edge/fog technology to migrate services closer to clients in order to improve response times do not fully resolve this problem as they do not focus on performance and interference issues at the migrated locations. This paper proposes INDICES framework that addresses these limitations by providing a novel solution that determines when and to which MDC a service should be migrated to and thus provides the desired performance. Empirical results validating our claims are presented using a setup comprising a centralized cloud and MDCs composed of heterogeneous hardware.
icfec.pdf (476.73 Ko) Télécharger le fichier
hal-01654656 , version 1 (04-12-2017)
  • HAL Id : hal-01654656 , version 1
Shashank Shekhar, Ajay Dev Chhokra, Anirban Bhattacharjee, Guillaume Aupy, Aniruddha Gokhale. INDICES: Exploiting Edge Resources for Performance-aware Cloud-hosted Services. ICFEC 2017 - 1st IEEE International Conference on Fog and Edge Computing, May 2017, Madrid, Spain. pp.1-6. ⟨hal-01654656⟩
Collections
CNRS INRIA INRIA2
263 Consultations
357 Téléchargements
