Abstract : Bi-level thresholding is a motion gesture recognition technique that mediates between false positives, and false negatives by using two threshold levels: a tighter threshold that limits false positives and recognition errors, and a looser threshold that prevents repeated errors (false negatives) by analyzing movements in sequence. In this paper, we examine the effects of bi-level thresholding on the workload and acceptance of end-users. Using a wizard-of-Oz recognizer, we hold recognition rates constant and adjust for fixed versus bi-level thresholding. Given identical recognition rates, we show that systems using bi-level thresholding result in significant lower workload scores on the NASA-TLX and accelerometer variance. Overall , these results argue for the viability of bi-level thresholding as an effective technique for balancing between false positives, recognition errors and false negatives.
