Detached eddy simulations of the flow over a cylinder at Re = 3900 using Open-FOAM a low-diffusion MUSCL scheme for LES on unstructured grids, Computers and Fluids, vol.136, p.152169, 2016. ,
A challenging test case for large eddy simulation: high Reynolds number circular cylinder flow, International Journal of Heat and Fluid Flow, vol.21, issue.5, pp.648-654, 2000. ,
DOI : 10.1016/S0142-727X(00)00056-4
An experimental study of entrainment and transport in the turbulent near wake of a circular cylinder, Journal of Fluid Mechanics, vol.18, issue.-1, pp.321-374, 1983. ,
DOI : 10.1017/S0022112072000679
Large Eddy Simulation of Flow around Circular Cylinders on Structured and Unstructured Grids I Numerical flow simulation II, pp.231-249, 2001. ,
Application of a Hybrid Variational Multiscale Model to Massively Separated Flows, 3AF, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01256081
Hybrid simulation of high-Reynolds number flows relying on a variational multiscale model, 6th Symposium on Hybrid RANS-LES Methods, pp.26-28, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01413453
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, p.13671383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
Numerical studies of flow over a circular cylinder at ReD=3900, Physics of Fluids, vol.35, issue.2, pp.403-417, 2000. ,
DOI : 10.1017/S0022112069001157
Simulation of the flow past a circular cylinder in the supercritical regime by blending RANS and variationalmultiscale LES models, Journal of Fluids and Structures, vol.47, p.114123, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01083801
Impact of dynamic subgrid-scale modeling in variational multiscale large-eddy simulation of bluff-body flows, Acta Mechanica, vol.25, issue.2, p.33093323, 2014. ,
DOI : 10.1017/S002211206600020X
Effects of Reynolds number and low-intensity freestream turbulence on the flow around a circular cylinder, Publ. No, vol.872, 1987. ,
Fluctuating lift on a circular cylinder: review and new measurements, Journal of Fluids and Structures, vol.17, issue.1, p.5796, 2003. ,
DOI : 10.1016/S0889-9746(02)00099-3
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Physics of Fluids, vol.37, issue.8, p.20, 2008. ,
DOI : 10.1088/0957-0233/15/6/003
URL : https://hal.archives-ouvertes.fr/hal-00383669
Large eddy simulations of the flow around a circular cylinder: effects of grid resolution and subgrid scale modeling, Wind and Structures, vol.6, issue.6, pp.6-419, 2003. ,
DOI : 10.12989/was.2003.6.6.419
Aspect ratio and end plate effects on vortex shedding from a circular cylinder, Journal of Fluid Mechanics, vol.203, issue.-1, 1992. ,
DOI : 10.1063/1.857488
