Relativistic entanglement and the Theory of Dilated Locality
Since his famous discussions with Niels Bohr, Albert Einstein considered quantum entanglement (QE) as a spooky action at a distance, due to the violation of locality necessary for the state of the particle entangled with its companion to share at same a distance, in such a way that if a notification that is not local but instantaneous could only cover that space at a speed superior to that of light. The Theory of Relativity (TR) with Quantum Theory (QT) would face a direct consequence of this; turning QE into the bone of contention between both theories, which are no more than the pillars of Physics. Contrary to predictions, in this work we will see that QE is the meeting point of both theories, so much so, that QE could be considered as the cornerstone of the Theory of Everything (TOE). Consistent with this, the entangled particles retain certain autonomy unknown to date, and in addition, they have relativistically entangled alter egos, which will hold the effect even when the original entangled particles are extremely separated from each other. These alter-egos can be considered as black holes (with their corresponding temperature and entropy) giving rise to a wormhole. This is possible since the locality dilates according to the Lorentz factor, which is accompanied by a contraction in the effective channel and in the temporal delay to cross that channel. All this takes place while space-time is curved (hyperspace) to generate the wormhole between both black holes. In other words, QE is a local effect of infinite range so it does not outpace the speed of light, and therefore QT is a complete theory that does not clash with TR. Finally, everything we have said has direct consequences on the link between entangled particles from the point of view of quantum communications in terms of the channel and its bandwidth, latency, capacity, robustness and security.
