The precedence-constrained asymmetric traveling salesman polytope, Mathematical Programming, pp.241-265, 1995. ,
DOI : 10.1007/BF01585767
Two terminal steiner tree polyhedra, Contributions to operations research and economics, pp.251-284, 1989. ,
A Set Covering Approach for the Double Traveling Salesman Problem with Multiple Stacks, Combinatorial Optimization: 4th International Symposium, ISCO 2016, pp.260-272, 2016. ,
DOI : 10.1007/978-3-642-02017-9_38
Multivalued Decision Diagrams for Sequencing Problems, Operations Research, vol.61, issue.6, pp.1411-1428, 2013. ,
DOI : 10.1287/opre.2013.1221
A New Formulation for the Travelling Salesman Problem, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.1, pp.21-25, 1984. ,
DOI : 10.1137/0605004
Improvements and extensions to the Miller-Tucker-Zemlin subtour elimination constraints, Operations Research Letters, vol.10, issue.1, pp.27-36, 1991. ,
DOI : 10.1016/0167-6377(91)90083-2
On a time-dependent formulation and an updated classification of ATSP formulations, Progress in Combinatorial Optimization, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00648457
On extended formulations for the precedence constrained asymmetric traveling salesman problem, Networks, vol.22, issue.2, pp.77-89, 2006. ,
DOI : 10.1002/net.20122
URL : https://hal.archives-ouvertes.fr/inria-00281586
The asymmetric travelling salesman problem and a reformulation of the Miller???Tucker???Zemlin constraints, European Journal of Operational Research, vol.112, issue.1, pp.134-146, 1999. ,
DOI : 10.1016/S0377-2217(97)00358-5
The asymmetric travelling salesman problem: on generalizations of disaggregated Miller???Tucker???Zemlin constraints, Discrete Applied Mathematics, vol.112, issue.1-3, pp.129-145, 2001. ,
DOI : 10.1016/S0166-218X(00)00313-9
Load-dependent and precedence-based models for pickup and delivery problems, Computers & Operations Research, vol.63, pp.56-71, 2015. ,
DOI : 10.1016/j.cor.2015.04.008
A Cutting Plane Algorithm for the Linear Ordering Problem, Operations Research, vol.32, issue.6, pp.1195-1220, 1984. ,
DOI : 10.1287/opre.32.6.1195
Classification of travelling salesman problem formulations, Operations Research Letters, vol.9, issue.2, pp.127-132, 1990. ,
DOI : 10.1016/0167-6377(90)90052-7
Stronger multi-commodity flow formulations of the (capacitated) sequential ordering problem, European Journal of Operational Research, vol.251, issue.1, pp.74-84, 2016. ,
DOI : 10.1016/j.ejor.2015.11.001
Zur allgemeinen Kurventheorie, Fundamenta Mathematicae, vol.10, pp.96-115, 1927. ,
DOI : 10.4064/fm-10-1-96-115
Integer Programming Formulation of Traveling Salesman Problems, Journal of the ACM, vol.7, issue.4, pp.326-329, 1960. ,
DOI : 10.1145/321043.321046
A comparative analysis of several asymmetric traveling salesman problem formulations, Computers & Operations Research, vol.36, issue.3, pp.637-654, 2009. ,
DOI : 10.1016/j.cor.2007.11.008
Models and algorithms for the Asymmetric Traveling Salesman Problem: an experimental comparison, EURO Journal on Transportation and Logistics, vol.7, issue.1, pp.113-133, 2012. ,
DOI : 10.1002/net.3230070103
Integer programming formulations of the travelling salesman problem, Proceedings of the IEEE International Conference of Circuits and Computers, pp.149-152, 1980. ,
