NMF and PCA as Applied to Gearbox Fault Data, Eds): Intelligent Data Engineering and Automated Learning -IDEAL 2015 LNCS 9375, pp.199-206, 2015. ,
DOI : 10.1007/978-3-642-32717-9_23
Estimation of the Spirometric Residual Volume (RV) by a Regression Built from Gower Distances, Biometrical Journal, vol.17, issue.2, pp.131-149, 1995. ,
DOI : 10.1002/bimj.4710370202
Nonnegative matrix and tensor factorizations . Applications to exploratory multi-way data analysis and blind source separation, 2009. ,
DOI : 10.1002/9780470747278
Convex and Semi-Nonnegative Matrix Factorizations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.1, pp.45-55, 2010. ,
DOI : 10.1109/TPAMI.2008.277
URL : http://ranger.uta.edu/~chqding/papers/Ding-Li-Jordan.pdf
Principal Component Analysis, 2002. ,
Applied Biclustering Methods for Big and High-dimensional data using R, Boca Raton FL, 2017. ,
Self-organizing Maps, p.pp, 2001. ,
Learning the parts of objects by nonnegative matrix factorization, Nature, vol.401, pp.788-791, 1999. ,
The non-negative matrix factorization toolbox for biological data mining, Source Code for Biology and Medicine, vol.8, issue.1, pp.10-11, 2013. ,
DOI : 10.1186/1751-0473-8-10
The impact of outliers in in the regression estimating TLC from age and some spirometric observations. Modelling, Simulation & Control, pp.1-19, 1989. ,
Wind Noise Reduction using Nonnegative Sparse Coding, Machine Learning for Signal Processing, pp.431-436, 2007. ,
DOI : 10.1109/mlsp.2007.4414345
URL : http://orbit.dtu.dk/fedora/objects/orbit:55706/datastreams/file_3848474/content/
Extraction of Dynamic Nonnegative Features from Multidimensional Nonstationary Signals, DMBD 2016, pp.557-566, 2016. ,
DOI : 10.1007/BF01436376
Convex non-negative matrix factorization with Rank-1 update for clustering, ICAISC 2015, pp.59-68, 2015. ,
Data clustering with semi-binary non-negative matrix factorization, LNAI, vol.5097, pp.705-716, 2008. ,
DOI : 10.1007/978-3-540-69731-2_68
URL : http://www.bsp.brain.riken.jp/~zdunek/Zdunek_ICAISCP07.pdf
Nonnegative matrix factorization and its application to pattern recognition and text mining, Proc. of the 13th Federated Conference on Computer Science and Information Systems, pp.11-16, 2013. ,
