New interface
Conference papers
Maximization of Attractiveness EV Tourist Routes
Abstract : This paper presents model and an algorithmic approach for the problem of generation optimal tourist route for electric vehicles (EVs). In the discussed problem a starting and a final point of a route are EV charging stations where tourist could charge the battery and then continue a journey. The main objective is to select to the route points of interests (POIs) which maximizing tourist attractiveness. Furthermore maximum length of the route is limited by the number of kilometers that the car can travel on a single battery charge. The model applied by us is the graph routing problem named as the Orienteering Problem with Time Windows (OPTW). In OPTW each location has positive score and a specific time interval in which a location can be visited. The solution of OPTW is a route (from the given starting to the ending point) with a fixed limit of length including a subset of locations. Moreover the route maximizes the total score of the locations visited in the predefined time intervals. As a solution we present the evolutionary algorithm with combines path relinking method instead crossover. Computational experiments are conducted on realistic database POIs and EV charging stations of Podlasie region in Poland. Tests results and execution time of the algorithm shows that the described solution could be a part of EV software module with generates the most interesting route.
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01656202
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, December 5, 2017 - 2:56:27 PM
Last modification on : Wednesday, December 6, 2017 - 1:21:02 AM
File
448933_1_En_44_Chapter.pdf
Identifiers
Citation
Joanna Karbowska-Chilinska, Pawel Zabielski. Maximization of Attractiveness EV Tourist Routes. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.514-525, ⟨10.1007/978-3-319-59105-6_44⟩. ⟨hal-01656202⟩
Share
Metrics
Record views
94
Files downloads
72
