The Fractional Calculus, 1974. ,
Fractional-Order Systems and Controls -Fundamentals and Applications, 2010. ,
Fractional Order Signal Processing -Introductory Concepts and Applications, 2012. ,
Fractional-order systems and PI/sup /spl lambda//D/sup /spl mu//-controllers, IEEE Transactions on Automatic Control, vol.44, issue.1, pp.208-214, 1999. ,
DOI : 10.1109/9.739144
Discretization schemes for fractional-order differentiators and integrators, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.49, issue.3, pp.363-367, 2002. ,
DOI : 10.1109/81.989172
Continued Fraction Expansion Approaches to Discretizing Fractional Order Derivatives?an Expository Review, Nonlinear Dynamics, vol.340, issue.5, pp.155-170, 2004. ,
DOI : 10.1007/s11071-004-3752-x
Time-domain implementation of fractional order controllers, IEE Proceedings - Control Theory and Applications, vol.152, issue.5, pp.539-552, 2005. ,
DOI : 10.1049/ip-cta:20045063
Computation of Fractional Order Derivative and Integral via Power Series Expansion and Signal Modelling, Nonlinear Dynamics, vol.27, issue.11, pp.1-15, 2006. ,
DOI : 10.1007/s11071-005-9000-1
Continued fractions approximation of the impulse response of fractional-order dynamic systems, IET Control Theory & Applications, vol.2, issue.7, pp.564-572, 2008. ,
DOI : 10.1049/iet-cta:20070205
Time Domain Design of Fractional Differ- Integrators Using Least-Squares. Signal Process, pp.2567-2581, 2006. ,
IIR approximations to the fractional differentiator/integrator using Chebyshev polynomials theory, ISA Transactions, vol.52, issue.4, pp.461-468, 2013. ,
DOI : 10.1016/j.isatra.2013.02.002
Approximations of higher-order fractional differentiators and integrators using indirect discretization, TURKISH JOURNAL OF ELECTRICAL ENGINEERING & COMPUTER SCIENCES, vol.23, pp.666-680, 2015. ,
DOI : 10.3906/elk-1212-137
New improved fractional order integrators using PSO optimisation, International Journal of Electronics, vol.11, issue.3, pp.490-499, 2015. ,
DOI : 10.1109/CEC.1999.785511
Optimal design of wideband infinite impulse response fractional order digital integrators using colliding bodies optimisation algorithm, IET Signal Processing, vol.10, issue.9, pp.1135-1156, 2016. ,
DOI : 10.1049/iet-spr.2016.0298
Studies of Fractional Order Differentiators and Integrators: A Survey. Signal Process, pp.386-426, 2011. ,
Optimal design of wideband digital integrators and differentiators using harmony search algorithm, Model.: Netw. Devices Fields. doi, pp.10-1002, 2016. ,
DOI : 10.1016/j.isatra.2015.08.012
Optimal and Accurate Design of Fractional Order Digital Differentiator ? An Evolutionary Approach. IET Signal Process, 2016. ,
Enhanced Colliding Bodies Optimisationbased Optimal Design of Wideband Digital Integrators and Differentiators, Int. J. Bio- Inspired Computation ,
Cuckoo Search via Levy Flights, IEEE World Congr, pp.210-214, 2009. ,
Cuckoo search: recent advances and applications, Neural Computing and Applications, vol.8, issue.4, pp.169-174, 2014. ,
DOI : 10.1007/s00170-012-4013-7
