Genetic Algorithm Adoption to Transport Task Optimization, International Joint Conference SOCO'16 Advances in Intelligent Systems and Computing, pp.366-375, 2016. ,
DOI : 10.1016/j.tre.2009.05.002
Optimization of Chosen Transport Task by Using Generic Algorithms, Lecture Notes in Computer Science, vol.45, issue.6, pp.197-205, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01637504
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.120, issue.2, pp.351-385, 2008. ,
DOI : 10.1287/opre.33.5.1050
Parallel Tabu Search Algorithm with Uncertain Data for the Flexible Job Shop Problem, Lecture Notes in Artificial Intelligence No, vol.2, issue.5, 2016. ,
DOI : 10.1016/0165-0114(79)90022-8
Tabu search, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-01389283
New block properties for the permutation flow shop problem with application in tabu search, Journal of the Operational Research Society, vol.52, issue.2, pp.210-220, 2001. ,
DOI : 10.1057/palgrave.jors.2601055
Traffic Signal Optimization with Greedy Randomized Tabu Search Algorithm, Journal of Transportation Engineering, vol.138, issue.8, 2012. ,
DOI : 10.1061/(ASCE)TE.1943-5436.0000404
A new branch-and-cut algorithm for the capacitated vehicle routing problem, Mathematical Programming, vol.100, issue.2, pp.423-445, 2004. ,
DOI : 10.1007/s10107-003-0481-8
Enhancing variable neighborhood search by adding memory: Application to a real logistic problem, Knowledge-Based Systems, pp.28-37, 2014. ,
Greedy randomized adaptive search procedures, International Series in Operations Research & Management Science, pp.219-249, 2003. ,
Technical and Organizational Improvements of Packaging Production Processes, Advances in Science and Technology, Research Journal, vol.10, issue.30, pp.182-192, 2016. ,
2. Branch-And-Bound Algorithms for the Capacitated VRP, pp.29-52, 2001. ,
DOI : 10.1137/1.9780898718515.ch2
URL : https://hal.archives-ouvertes.fr/in2p3-00003512
