Restricted Binary Strings and Generalized Fibonacci Numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We provide some interesting relations involving k-generalized Fibonacci numbers between the set $F_n^{(k)}$ of length n binary strings avoiding k of consecutive 0’s and the set of length n strings avoiding $k+1$ consecutive 0’s and 1’s with some more restriction on the first and last letter, via a simple bijection. In the special case $k=2$ a probably new interpretation of Fibonacci numbers is given.Moreover, we describe in a combinatorial way the relation between the strings of $F_n^{(k)}$ with an odd numbers of 1’s and the ones with an even number of 1’s.
447449_1_En_3_Chapter.pdf (301.53 Ko) Télécharger le fichier
hal-01656354 , version 1 (05-12-2017)
Paternité
Antonio Bernini. Restricted Binary Strings and Generalized Fibonacci Numbers. 23th International Workshop on Cellular Automata and Discrete Complex Systems (AUTOMATA), Jun 2017, Milan, Italy. pp.32-43, ⟨10.1007/978-3-319-58631-1_3⟩. ⟨hal-01656354⟩
80 Consultations
138 Téléchargements
