Equicontinuity and Sensitivity of Nondeterministic Cellular Automata
Nondeterministic Cellular Automata (NCA) are the class of multivalued functions characterized by nondeterministic block maps. We extend the notions of equicontinuity and sensitivity to multivalued functions and investigate the characteristics of equicontinuous, almost equicontinuous and sensitive NCA. The dynamical behavior of nondeterministic CA in these classes is much less constrained than in the deterministic setting. In particular, we show that there are transitive NCA with equicontinuous points and equicontinuous NCA that are not reversible.
Informatique [cs]
