State Complexity of Suffix Distance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Timothy Ng
  • Fonction : Auteur
  • PersonId : 1022716
David Rappaport
  • Fonction : Auteur
  • PersonId : 1022714
Kai Salomaa
  • Fonction : Auteur
  • PersonId : 1022715
The neighbourhood of a regular language with respect to the prefix, suffix and subword distance is always regular and a tight bound for the state complexity of prefix distance neighbourhoods is known. We give upper bounds for the state complexity of the neighbourhood of radius k of an n state DFA (deterministic finite automaton) language with respect to the suffix distance and the subword distance, respectively. For restricted values of k and n we give a matching lower bound for the state complexity of suffix distance neighbourhoods.
440206_1_En_23_Chapter.pdf (294.82 Ko) Télécharger le fichier
hal-01656995 , version 1 (06-12-2017)
Paternité
Timothy Ng, David Rappaport, Kai Salomaa. State Complexity of Suffix Distance. 19th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2017, Milano, Italy. pp.287-298, ⟨10.1007/978-3-319-60252-3_23⟩. ⟨hal-01656995⟩
42 Consultations
107 Téléchargements
