Full-Abstraction for Must Testing Preorders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Giovanni Bernardi
  • Fonction : Auteur
  • PersonId : 1024623
Adrian Francalanza
  • Fonction : Auteur
  • PersonId : 1024624
The client ${\mathsf {must}}$ preorder relates tests (clients) instead of processes (servers). The existing characterisation of this preorder is unsatisfactory for it relies on the notion of usable clients which, in turn, are defined using an existential quantification over the servers that ensure client satisfaction. In this paper we characterise the set of usable clients for finite-branching LTSs, and give a sound and complete decision procedure for it. We also provide a novel coinductive characterisation of the client preorder, which we use to argue that the preorder is decidable, thus positively answering the question opened in [3, 6].
450044_1_En_13_Chapter.pdf (198.4 Ko) Télécharger le fichier
hal-01657337 , version 1 (06-12-2017)
Paternité
Giovanni Bernardi, Adrian Francalanza. Full-Abstraction for Must Testing Preorders. 19th International Conference on Coordination Languages and Models (COORDINATION), Jun 2017, Neuchâtel, Switzerland. pp.237-255, ⟨10.1007/978-3-319-59746-1_13⟩. ⟨hal-01657337⟩
103 Consultations
73 Téléchargements
