js 3. 0[library]: operative. https://github.com/padolsey/operative 4. 0[library]: parallel.js. https://github.com/parallel-js/parallel.js 5. 0[library]: q-connection. https://github.com/kriskowal/q-connection 6. 0[library]: tiny-worker. https://github.com/avoidwork/tiny-worker 7. 0[standard] Ecma International: ECMA-262 ,
Reo: a channel-based coordination model for component composition, Mathematical Structures in Computer Science, vol.14, issue.3, pp.329-366, 2004. ,
DOI : 10.1017/S0960129504004153
Puff, The Magic Protocol, Biological Systems, pp.169-206, 2011. ,
DOI : 10.1007/978-3-642-21464-6_13
Modeling component connectors in Reo by constraint automata, Science of Computer Programming, vol.61, issue.2, pp.75-113, 2006. ,
DOI : 10.1016/j.scico.2005.10.008
43 years of actors: a taxonomy of actor models and their key properties, Proceedings of the 6th International Workshop on Programming Based on Actors, Agents, and Decentralized Control, AGERE 2016, pp.31-40, 2016. ,
DOI : 10.1145/28697.28722
River Trail: A Path to Parallelism in JavaScript, Proceedings of OOPSLA 2013, pp.729-744, 2013. ,
Multiparty Asynchronous Session Types, ACM SIGPLAN Notices (Proceedings of POPL 2008, pp.273-284, 2008. ,
DOI : 10.1145/1328897.1328472
Automata-Theoretic Protocol Programming, 2016. ,
PrDK: Protocol Programming with Automata, Proceedings of TACAS 2016, pp.547-552, 2016. ,
DOI : 10.1007/978-3-662-49674-9_33
Overview of Thirty Semantic Formalisms for Reo, Scientific Annals of Computer Science, vol.22, issue.1, pp.201-251, 2012. ,
DOI : 10.7561/SACS.2012.1.201
Can High Throughput Atone for High Latency in Compiler-Generated Protocol Code?, Fundamentals of Software Engineering (Proceedings of FSEN 2015), pp.238-258, 2015. ,
DOI : 10.1007/11767954_18
URL : https://hal.archives-ouvertes.fr/hal-01446603
Concurrent and asynchronous JavaScript programming using Reo, 2017. ,
Many spiders make a better web: a unified web-based actor framework, Proceedings of the 6th International Workshop on Programming Based on Actors, Agents, and Decentralized Control, AGERE 2016, pp.51-60, 2016. ,
DOI : 10.1145/2490257.2490292
Pabble: parameterised Scribble, Service Oriented Computing and Applications, vol.17, issue.2, pp.3-4, 2015. ,
DOI : 10.1145/277650.277732
URL : http://doi.org/10.1007/s11761-014-0172-8
On the criteria to be used in decomposing systems into modules, Communications of the ACM, vol.15, issue.12, pp.1053-1058, 1972. ,
DOI : 10.1145/361598.361623
Dependence-driven delimited CPS transformation for JavaScript, Proceedings of GPCE 2016, pp.59-69, 2016. ,
DOI : 10.1145/3093335.2993243
Are web applications ready for parallelism?, Proceedings of PPoPP 2015, 2015. ,
DOI : 10.1145/2688500.2700995
Akka. js: Towards a portable actor runtime environment, Proceedings of AGERE! 2015, pp.57-64, 2015. ,
Generic workers, Programming Support Innovations for Emerging Distributed Applications on, PSI EtA '10, 2010. ,
DOI : 10.1145/1940747.1940748
Promises and Asynchronous Programming, Understanding EC- MAScript, vol.6, issue.11, pp.213-241, 2016. ,
