A Review of Rapid Serial Visual Presentation-based Brain-Computer Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Neural Engineering Année : 2017
Rapid serial visual presentation (RSVP) combined with the detection of event related brain responses facilitates the selection of relevant information contained in a stream of images presented rapidly to a human. Event related potentials (ERPs) measured non-invasively with electroencephalography (EEG) can be associated with infrequent targets amongst a stream of images. Human-machine symbiosis may be augmented by enabling human interaction with a computer, without overt movement, and/or enable optimization of image/information sorting processes involving humans. Features of the human visual system impact on the success of the RSVP paradigm, but pre-attentive processing supports the identification of target information post presentation of the information by assessing the co-occurrence or time-locked EEG potentials. This paper presents a comprehensive review and evaluation of the limited but significant literature on research in RSVP-based brain-computer interfaces (BCIs). Applications that use RSVP-based BCIs are categorized based on display mode and protocol design, whilst a range of factors influencing ERP evocation and detection are analyzed. Guidelines for using the RSVP-based BCI paradigms are recommended, with a view to further standardizing methods and enhancing the inter-relatability of experimental design to support future research and the use of RSVP-based BCIs in practice.
JNE_RSVP review_revision - FInal submitted.pdf (714.08 Ko) Télécharger le fichier
hal-01657643 , version 1 (07-12-2017)
Stephanie Lees, Natalie Dayan, Hubert Cecotti, Paul Mccullagh, Liam Maguire, et al.. A Review of Rapid Serial Visual Presentation-based Brain-Computer Interfaces. Journal of Neural Engineering, 2017, pp.1-39. ⟨10.1088/1741-2552/aa9817⟩. ⟨hal-01657643⟩
257 Consultations
473 Téléchargements
