Community Discovery in Dynamic Networks: a Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Computing Surveys Année : 2018
Several research studies have shown that Complex Networks modeling real-world phenomena are characterized by striking properties: (i) they are organized according to community structure and (ii) their structure evolves with time. Many researchers have worked on methods that can efficiently unveil substructures in complex networks, giving birth to the field of community discovery. A novel and fascinating problem started capturing researcher interest recently: the identification of evolving communities. Dynamic networks can be used to model the evolution of a system: nodes and edges are mutable and their presence, or absence, deeply impacts the community structure that composes them. This survey aims to present the distinctive features and challenges of dynamic community discovery and propose a classification of published approaches. As a " user manual " , this work organizes state of the art methodologies into a taxonomy, based on their rationale, and their specific instan-tiation. Given a definition of network dynamics, desired community characteristics and analytical needs, this survey will support researchers to identify the set of approaches that best fit their needs. The proposed classification could also help researchers to choose in which direction to orient their future research.
1707.03186-4.pdf (2.36 Mo) Télécharger le fichier
hal-01658399 , version 1 (07-12-2017)
hal-01658399 , version 2 (04-09-2019)
Giulio Rossetti, Rémy Cazabet. Community Discovery in Dynamic Networks: a Survey. ACM Computing Surveys, 2018, 2 (51), pp.35. ⟨10.1145/3172867⟩. ⟨hal-01658399v2⟩
455 Consultations
2348 Téléchargements
