Abstract : The high availability and scalability of weakly-consistent system attracts system designers. Yet, writing correct application code for this type of systems is difficult; even how to specify the intended behavior of such systems is still an open question. There has not been established any standard method to specify the intended dynamic behavior of a weakly consistent system.In this paper, we present a event-based parallel temporal logic (EPTL), that is tailored to specify properties of weakly consistent systems. In contrast to LTL and CTL, EPTL takes into account that operations of weakly consistent systems are in many cases not serializable and have to be treated respectively to capture their behavior. We embed our temporal logic in Isabelle/HOL and can thereby leverage strong semi-automatic proving capabilities.
https://hal.inria.fr/hal-01658414 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, December 7, 2017 - 3:48:43 PM Last modification on : Thursday, December 7, 2017 - 3:50:49 PM
Mathias Weber, Annette Bieniusa, Arnd Poetzsch-Heffter. EPTL - A Temporal Logic for Weakly Consistent Systems (Short Paper). 37th International Conference on Formal Techniques for Distributed Objects, Components, and Systems (FORTE), Jun 2017, Neuchâtel, Switzerland. pp.236-242, ⟨10.1007/978-3-319-60225-7_17⟩. ⟨hal-01658414⟩
