Event-clock automata: a determinizable class of timed automata, Theoretical Computer Science, vol.211, issue.1-2, pp.253-273, 1999. ,
DOI : 10.1016/S0304-3975(97)00173-4
Parametric real-time reasoning, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.592-601, 1993. ,
DOI : 10.1145/167088.167242
URL : http://www-cad.eecs.berkeley.edu/~tah/Publications/parametric_real-time_reasoning.pdf
What's decidable about parametric timed automata?, pp.1-17, 2015. ,
An inverse method for parametric timed automata, IJFCS, vol.20, issue.5, pp.819-836, 2009. ,
IMITATOR 2.5: A Tool for Analyzing Robustness in Scheduling Problems, FM. LNCS, 2012. ,
DOI : 10.1007/978-3-642-32759-9_6
Decision Problems for Parametric Timed Automata, ICFEM. LNCS, pp.400-416, 2016. ,
DOI : 10.1007/3-540-46430-1_26
Reachability Preservation Based Parameter Synthesis for Timed Automata, NFM. LNCS, pp.50-65 ,
DOI : 10.1007/978-3-319-17524-9_5
Language Preservation Problems in Parametric Timed Automata, FORMATS. LNCS, pp.27-43, 2015. ,
DOI : 10.1007/978-3-319-22975-1_3
Compositional parameter synthesis, FM. LNCS, pp.60-68, 2016. ,
Breaking up is hard to do, ACM Transactions on Software Engineering and Methodology, vol.17, issue.2, pp.1-752, 2008. ,
DOI : 10.1145/1348250.1348253
Learning Assumptions for Compositional Verification, TACAS. LNCS, pp.331-346, 2003. ,
DOI : 10.1007/3-540-36577-X_24
A Counterexample-Guided Approach to Parameter Synthesis for Linear Hybrid Automata, HSCC. LNCS, 2008. ,
DOI : 10.1007/978-3-540-78929-1_14
Linear parametric model checking of timed automata, pp.52-53, 2002. ,
Integer Parameter Synthesis for Real-Time Systems, IEEE Transactions on Software Engineering, vol.41, issue.5, pp.445-461, 2015. ,
DOI : 10.1109/TSE.2014.2357445
Learning assumptions for compositional verification of timed systems, TSE, vol.40, issue.2, pp.137-153, 2014. ,
