Abstract : We propose the notion of weak simulation quasimetric as the quantitative counterpart of weak simulation for probabilistic processes. This is an asymmetric variant of the weak bisimulation metric of Desharnais et al. which maintains most of the properties of the original definition. However, our asymmetric version is particularly suitable to reason on protocols where the systems under consideration are not approximately equivalent. As a main application, we adopt our simulation theory in a simple probabilistic timed process calculus to derive an algebraic theory to evaluate the performances of gossip protocols.
https://hal.inria.fr/hal-01658428 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, December 7, 2017 - 3:49:26 PM Last modification on : Monday, March 21, 2022 - 5:22:04 PM
Ruggero Lanotte, Massimo Merro, Simone Tini. Weak Simulation Quasimetric in a Gossip Scenario. 37th International Conference on Formal Techniques for Distributed Objects, Components, and Systems (FORTE), Jun 2017, Neuchâtel, Switzerland. pp.139-155, ⟨10.1007/978-3-319-60225-7_10⟩. ⟨hal-01658428⟩
