Humusica 1, article 3: Essential bases ‒ Quick look at the classification
Abstract : Terms and concepts have been defined in Humusica 1, article 1 and the functioning of humus systems has been discussed in Humusica 1, article 2. Here a short overview of the matter, showing humus systems in their environment, is provided for beginners, before making field investigations. The present work is intended as a part of the field manual (Humusica 1 and 2), an illustrated, easy-to-use application tool for humus systems classification, helpful even for not (yet) expert pedologists. The present article gives also a fast look at the classification, sharing Terrestrial, Histic, Aqueous and Para humus systems, every group being defined by its characteristics set in synthetic tables, and suggests a step-by-step approach allowing everyone to classify and investigate humus systems and forms.
Liste complète des métadonnées
Littérature citée [54 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-01658526
Contributeur : Jean-François Ponge <>
Soumis le : jeudi 7 décembre 2017 - 16:36:17
Dernière modification le : vendredi 12 octobre 2018 - 12:02:16
Fichier
Article 3.pdf
Fichiers produits par l'(les) auteur(s)
Domaine public
Collections
PSL
Citation
Augusto Zanella, Jean-François Ponge, Rein De Waal, Chiara Ferronato, Maria De Nobili, et al.. Humusica 1, article 3: Essential bases ‒ Quick look at the classification. Applied Soil Ecology, Elsevier, 2018, 122 (Part 1), pp.42-55. 〈10.1016/j.apsoil.2017.05.025〉. 〈hal-01658526〉
Métriques
Consultations de la notice
267
Téléchargements de fichiers
69
