The Latent Block Model: a useful model for high dimensional data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Latent Block Model (LBM) designs in a same exercise a clustering of the rows and the columns of a data array. Typically the LBM is expected to be useful to analyze huge data sets with many observations and many variables. But it encounters several numerical issues with big data set: maximum likelihood is jeopardized by spurious maxima and selecting a proper model is challenging since there are a lot of models are in competition. In this communication, we analyze these numerical issues. In particular, we make use of Bayesian inference to avoid spurious solutions and propose an efficient way to scan the model set. Moreover, we advocate the exact Integrated Completed Likelihood (ICL) criterion to select a proper and consistent LBM. The methods and algorithms will be ilustrated with pharmacovigilance data involving large arrays of data.
KERIBIN-CELEUX-ROBERT-ISI17.pdf (426.86 Ko) Télécharger le fichier
hal-01658589 , version 1 (07-12-2017)
  • HAL Id : hal-01658589 , version 1
Christine Keribin, Gilles Celeux, Valérie Robert. The Latent Block Model: a useful model for high dimensional data. ISI 2017 - 61st world statistics congress, Jul 2017, Marrakech, Morocco. pp.1-6. ⟨hal-01658589⟩
792 Consultations
1156 Téléchargements
